general questions regarding implements.
   / general questions regarding implements. #1
RCannon
Bronze Member
thumb of Michigan
TC33D
First my info....I'm considering buying a tractor and know little about them so I have a few questions. /forums/images/graemlins/confused.gif
1. Belly mount versus a tow behind rear discharge. thoughts? I have a four wheeler with a mower behind it so I am used to it.
2. Box scaper versus a blade? do I need a blade? How often does one use a blade or scraper? We live in mid michigan
3. Ten acres of land with a pond here. I mow maybe 4 max..How big of a tractor is REALLY necessary?
   / general questions regarding implements. #2
With a small tractor you'd probably spend about 8 hours mowing your 4 acres. If it is lawn you'll need a finish mower, if it is field, a bush hog. I assume you want to grade your driveway which is the main use for a blade of some sort. What else did you have in mind.
   / general questions regarding implements. #3
Hi RCannon,
Welcome to TBN...
I bought a RFM with my B2910 last year and it is good, except when cutting around things like my pond or close to a fence or around trees. The problem is that I got a 60" and my rear tires are 54 inches wide. Almost no overhang, so it is difficult to cut close to things.
Additionally when cutting around the edge of the pond, as the tractor wheels move left for example, the mower tends to move away from the pond edge, rather than closer to it as a MMM would.
My advice is to get as wide a RFM as you can and to get a rear discharge unit too, so you can get in close as possible on either side.
I am trading in my RFM towards the purchase of a Kubota BX with MMM. [note I said RFM, not the B2910, that stays!] My property is such that the bx makes more sense, lots of trees and different things to get in the way, and very little solid, open patches of grass to cut, where the rfm would shine. We only have 3.7 acres to deal with.
A rear blade works better in the snow than the box scraper, at least for me. The box scraper is a wonderful tool if you are dealing with moving/cleaning up dirt as it is dragged on the surface and will follow the ground. Also with the scarifiers down it will dig the hard stuff much better than my cheap back blade...
Tractor size is dependent upon what you want to do and how fast. You probably don't need anything bigger than a BX Kubota or something similar...unless you want to lift something heavier than the about 400 lbs that the loader maxes out at... /forums/images/graemlins/smile.gif
Do some searches of the archives...you will find a wealth of info/experience/opinion on tractor sizing needs!
Thnaks for answers guys.
The MMM is sounding better as we have a LOT of trees to mow around..although not very big.
We do a lot of landscaping, hauling mulch, making flower beds, gardening etc...
Blade will be used for grading the driveway and maybe smoothing some dirt on occasion.
As for how large of tractor... I'm just trying not to be influenced by testosterone levels /forums/images/graemlins/grin.gif
   / general questions regarding implements. #5
Remember, the bigger the tractor, the less you can manuver it around. If you do any plowing or tilling those beds in soft stuff, the MMM might get in the way. Please fill out more of your BIO for us. /forums/images/graemlins/cool.gif
</font><font color="blue" class="small">( the MMM might get in the way )</font>
How easy is it to take this off?
I like the idea of a tiller, but after spring how much use does it have?
back to the mowers..
rear discharge mowers..good/bad?
thanks again!
   / general questions regarding implements. #7
<font color="blue"> 2. Box scaper versus a blade? do I need a blade? How often does one use a blade or scraper? We live in mid michigan
</font>
Box scraper is good for dirt, gravel and such but about worthless for snow. Rear blade is great for snow and somewhat useful for dirt etc. Where in Mid-Michigan? If you are in lake effect areas even a rear blade can be challenged. FEL and/or snowblower could be in order for deep snow /forums/images/graemlins/smile.gif
In the center of the thumb..Imlay City.
I will have the FEL thanks to all the convincing posts here and the hours of backache at home. /forums/images/graemlins/crazy.gif
I was leaning towards the rear blade.
This is probably the wrong forum to ask this, so maybe someone can point out the right one... Tires...ag or turf? Filled or not?
thanks
   / general questions regarding implements. #9
<font color="blue"> Tires...ag or turf? Filled or not?
</font>
Do a search, there has been a lot of discussion on tires in the past. If you don't find everything there is to know about them, start a new thread /forums/images/graemlins/smile.gif
Thanks Rob...this statement sorta summed it up...
</font><font color="blue" class="small">( <font color="blue"> In summary to this point, we have those who swear by R4's, those who swear at R4's, those who prefer R1's, those who like R3's. I guess it's one of those "Actual mileage may vary" types of things, depends on your lawn, soil type, driving style, etc.
</font> )</font>
Ahhh...Confusion..the 51st state /forums/images/graemlins/smirk.gif
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
2023 Jeep Compass Trail Hawk 4x4 SUV (A51694)
2023 Jeep Compass...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53473)
GALAXY - SET OF...
