Mowing General maint question on TT75A
   / General maint question on TT75A #1
JeffDR
Enid, OK
New Holland TT75A
Hello for my first post....
I've borrowed my friends New Holland TT75A, 4 wheel drive, with front loader and 1 rear remote several times for my 2+ acre yard work. I really appreciate being able to use the tractor and want to repay him by giving the tractor a good servicing.
Strangely enough, he does not use the tractor. He bought it for use to mow pastures and general work by his son in law and son's. I put a few hours on it and it hit me to check the oil, fluids etc. I used almost a tube of grease on this thing. Bad sign for me so time for more checking.
I don't know what they are called, but on the 3 point hitch, the 2 vertical tubes.... Towards the bottom there are what appears to be grease zerts, but it looks like they are broken off. Are those supposed to be grease zerts? Or just round silver looking bulbs.
I also want to change the oil for him since it is as black as a black crayon. I just don't know where to find the drain plug, how much oil to get, or what kind or weight oil to use. I see a couple filters, but don't know which one is for the oil or fuel. All filters say New Holland and more than likely, they are the original filters. Heck, I might as well change the fuel filter while I'm at it.
What I call the throttle fritction control, or the lever on the dash to adjust the throttle.... does not work, I've been using the foot throttle. I can look thru the slit and see the connector on the arm, but no cable. Is this something I can just stick the cable back in and give it a good crimp? Or do I need to get a new cable assembly?
I'm not going to fool with the front wheel seal. Seems like a huge job and there is enough things I will take care of for him.
Looks like I may be using this tractor for pasture mowing and I want it to be in tip top shape. No owners or service manual so any pointers are very welcome.
Thanks for any advice,
Jeff
   / General maint question on TT75A #2
  • 0.30.2_01 OIL FILTER.pdf
  • 0.20.0 FUEL FILTER.pdf
   / General maint question on TT75A #3
Also, welcome to TBN!
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2016 JLG ECOLIFT...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2022 JOHN DEERE 85G EXCAVATOR (A51242)
2022 JOHN DEERE...
ATTENTION! PLEASE READ (A50120)
ATTENTION! PLEASE...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2016 Ford F-450...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
