Gelled Fuel
   / Gelled Fuel #1
mtncur
Grand Rivers, Kentucky
John Deere 5083e, Kubota L3240
I think my fuel may have become gelled. Bought 400 gallon of fuel back in the summer so maybe it had no treatment? Anyway it痴 been single digits here with windchills below zero. I keep my 5083e plugged in so it always fires right up. However, went to set out hay and about 100 yards it quits like it ran out of fuel. I致e tried everything. Put emergency anti gel in the fuel and filter and it would start and run a minute then seem to run out again. I eventually drained the tank and bought new fuel from the gas station and added treatment and a new fuel filter. It ran a few hundred feet and quit again. Itll start on ether and pick up on fuel and run a bit then quit again. I知 baffled and I致e got to have this tractor to set out hay. No relief in sight for temps. Any ideas on getting it going. Gelled fuel was my first thought but now I知 starting to wonder. Any ideas?
   / Gelled Fuel #3
First of all don't feed it ether unless it's certified for diesel, try WD40.
It may still be too cold for your fuel. Name your treatment. I'd put in PS, maybe double the dose, and if you can get a plastic bag around the fuel filter bag it and pour hot water in the bag and keep emptying the bag and pouring hot water in until the fuel filter gets warm.
I did that to a VW diesel that gelled due to summer fuel at 40 below.
/edit jc posted while I was composing - now IF you can get the fuel filter off easy and restart then just take the filter out and dump the wax, refill and restart.
The main thing is to ensure that you don't have a block of wax in the filter.
For example I can only access my VW filter from the top and can slide a bag down and around it, I can't get a heat gun on it other than from the top.
   / Gelled Fuel #4
Looks like the temps for you will be near 30 deg tomorrow.. hope you can get the filter warmed up (like the warm water suggestion) and then cranked enough to keep the engine running.
Sounds like you may not be near an electrical outlet.. or hope you have a generator handy.
Keep us posted..
   / Gelled Fuel
I do have an outlet nearby in my garage. I keep the block heater plugged in. I will try warming the filter tomorrow with a heat gun. My garage is toasty warm with wood heat but the door clearance is only 8 ft. My tractor needs 8’3” to clear. I’ve considered letting air out of the tires but I’m not sure I would gain enough.
   / Gelled Fuel #6
Had a similar issue a couple years back. Tarped the tractor and pointed a 50.000 BTU salamander under the tarp for a couple hours. It started and ran like the middle of summer afterward.
   / Gelled Fuel
I think I will try tarping today after work. I wonder if another new fuel filter is warranted. I feel I may have gummed the new one up yesterday before I drained all the fuel.
   / Gelled Fuel #8
You should replace the filter, it is very difficult to suspend the wax that separates out, you could have wax in the pump and injector lines, lots of heat will help.
   / Gelled Fuel #10
Okay, lots of good advice here. I'm going to touch on one thing I haven't seen mentioned and I think when done I'll copy and paste to some other threads.
In sub zero temperatures cut down on the exposure to the outside air for your equipment,
put a plastic trash bag in front of your grill to stop the air flow, wrap a bungee cord around to hold it in place, as it warms up you can give it some air if needed, just slid your cover down a bit.
Get a small tarp and more bungee cords wrap it around the hoods on your tractor under the engine and on both sides.
When you get to using it open up the front to get a little air in, watch your temperature gauges unless you are working
your engine hard it will need very little air, the heat that you trap will warm your fuel lines and filter.
If its making heat then you can open up the rear a bit and let some come back to your feet, it will be like the old heat housers
we used to put on and a few of use still do at times.
Let these diesel run warm they will work better and last longer, note I said warm not to hot :thumbsup:
2007 John Deere Gator 6x4 Utility Cart (A51691)
2007 John Deere...
2018 LAMAR TRAILER 40' T/A GOOSENECK TRAILER (A53843)
2018 LAMAR TRAILER...
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2015 BMW 320i Sedan (A53117)
2015 BMW 320i...
78'' skid steer bucket (A53421)
78'' skid steer...
