Gearskift probem, Zetor 4718/4712
   / Gearskift probem, Zetor 4718/4712 #1
JensJakob
Hi
I have a problem with my Zetor 4718.
I can shift into 3+4.
I can move gearshift sideways to 1+1 position, but not move it up or down to shift into 1+2.
I cannot move it all the way sideways to 5+R.
I think that a shiftfork have jumped out of place.
Should I remove the house connecting shiftstick to gearbox and see if something have jumped out of place?
I have also read about the bolts on top of the gearbox, that can be removed, and give direct access to shiftforks.
Is this true too on the 4718?
Any good tips, hint, faqs, images etc. on how to fix this gearbox problem?
Best regards
Jens Jakob
   / Gearskift probem, Zetor 4718/4712 #2
Jens- Go to www.zetorna.com and go to forums, then they have a technical section were you can ask the question and get a response from a Zetor service representitive.
Chuck
Thank you very much for the tip.
Best regards
Jens Jakob
2015 JCB 930 6,000lbs 4x4 Rough Terrain Straight Mast Forklift (A50322)
2015 JCB 930...
Grundfos Centrifugal Pump (A50121)
Grundfos...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2005 TerraGator 8104 (A52748)
2005 TerraGator...
2018 Bobcat E10 (A50121)
2018 Bobcat E10...
2018 JLG 4045R 40ft Electric Scissor Lift (A50322)
2018 JLG 4045R...
