gearbox oil?
   / gearbox oil? #1
Den1952
Bronze Member
Weyauwega Wi
InternationalHarvestor tlh
I have an older gravely, the engine was past being able to rebuild and I got a fresh 8 hp kohler for it.
I had enough trouble mounting the engine to the gearbox but finally did get it on by using a floor jack to hold up the engine.
I hadn't been able to use it til now, and am wondering what type of oil to use in the gearbox. I did put one gallon of 80-90 in it. and found it had a bad leak where the engine couples up. I didn't have an original gasket for it so I made one out of a rubbery type of material. should I have used a tube of gasket maker (comes in a tube like a toothpaste. instead? I am wondering if I can properly apply the gasket maker paste with only pulling the engine about 1/4" from the gear box?
good news for the "field test" though, I used the brush cutter up front for mowing a weeded over area inside the pines. it worked great! didn't take me too long to figure out the 3 or 4 different controls for it. low range was much more comfortable to work with, plenty fast for walking. high range must be a road gear or for a sulky traveling on a lawn?
   / gearbox oil? #2
If you're talking about the "gearbox" being the main transmission housing, get that 80-90 out of it ASAP!!!
I run SAE-30 in mine. That's what they were designed for in the old days when the transmission shared the same oil with the engine. I did see someone else on here (I think) that was running 10W-30 in his.
I do run 80-90 in the gearbox on my mower head, rotary plow, etc.
   / gearbox oil?
thanks for the reply. today i did a search for gravely manuals and found this site.
Gravely Tractor Club - Gravely Manuals
i hope this link works in this post,,,
i would suppose most of the gravely owners here have already found all the sources for manuals etc
but here it is again.
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
1983 Case 580D (A47477)
1983 Case 580D...
Light Tower (A52377)
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
