Gearbox capacity and oil type? Tiller Kubota FL1270
   / Gearbox capacity and oil type? Tiller Kubota FL1270 #1
Daveyboy
New Holland T1510
Kubota Tiller FL 1270
Gearbox Part # 70494-51110
I have been searching for an operator’s manual with no luck.
I think I need one of 2 things. I either need to find out the oil capacity and oil type for this gear box or I need someone with experience to tell me how to fill this so I don’t use too much or too little oil.
Thanks in advance for your help.
   / Gearbox capacity and oil type? Tiller Kubota FL1270 #3
There should be some marks or bolt hole to fill to
willy
   / Gearbox capacity and oil type? Tiller Kubota FL1270 #4
Gear box refill from empty is 1.06 qts of sae 90 gear oil. The chain case is 1.27 it's from empty of sae 90 gear oil
   / Gearbox capacity and oil type? Tiller Kubota FL1270 #5
Gear box refill from empty is 1.06 qts of sae 90 gear oil. The chain case is 1.27 from empty of sae 90 gear
   / Gearbox capacity and oil type? Tiller Kubota FL1270 #6
Book says to fill gear box to center of pinion shaft
Aerator (A49251)
Aerator (A49251)
MISC 5 PIPE (A48992)
Skid Steer Auger Drive & Bit Set (A47371)
Skid Steer Auger...
4 New Toyo Tires 205/60/16 (A47371)
4 New Toyo Tires...
TOYOTA FGU35 FORKLIFT (A48992)
TOYOTA FGU35...
Lift Gate (A49251)
Lift Gate (A49251)
