Gear shift stuck in gear on Craftsman 2001 model 917.272430 How do I repair.
   / Gear shift stuck in gear on Craftsman 2001 model 917.272430 How do I repair. #1
llarr
Lakeland, FL
Craftsman 917.27686
Our tractor's gear shifter is stuck in 4th how do I fix it. It is a 2001 Craftsman model 917.272430. Thank You'
   / Gear shift stuck in gear on Craftsman 2001 model 917.272430 How do I repair. #2
Have you determined if it is the shifter that's stuck, or the transmission? You may want to unhook the linkage and see what moves and what doesn't.
   / Gear shift stuck in gear on Craftsman 2001 model 917.272430 How do I repair. #3
Had one of those Sears mowers from about that time that was always hard shifting. Seemed to bind up right where it went into the gearbox under the seat. Kept lubing it up with WD40 and penetrating oil to no avail. Sad to say, the shift arm finally broke right at the gearbox and I unloaded the otherwise good little mower as I didn't have time to tear it apart to fix it. With mine, I figured it was some combination of dirt and rust that caused the binding because we had no place to store it and it sat out for quite a while.
RoGator RG1100C (A53473)
RoGator RG1100C...
90004 (A51694)
90004 (A51694)
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2020 KUBOTA RTV...
2017 Ram ProMaster City Cargo Van (A51692)
2017 Ram ProMaster...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A53473)
Adams Load Out...
