gear rebuilding service?
   / gear rebuilding service? #1
bill_396
The final reduction gears on the right side of my Yanmar compact tractor are damaged and I have not been able to find replacements. The 3" dia. straight cut pinion has half a tooth broken and the next tooth has a crack in half of it. The mating 12" gear has minor damage in 8 to 12 teeth from meshing with the broken pinion. Can these be welded up and recut? Any suggested sources? Thanks, Bill.
   / gear rebuilding service? #2
Bill I have had some sucess of getting a machine shop to weld and cut or at times completely make one. If all else fails try that or at least i would check it out to see if they can. [/list]
   / gear rebuilding service? #3
I sympathize with you as I owned a Bison/Shenniu for 5 years and it was always a game finding parts for it. I would think that there are more than a few tractor recyclers with Yanmars to part out. I would use the Google search engine and let your fingers do the walking for you.
I wish you luck in finding your parts.
From studying manuals from similar model Yanmars it appears that I need to find the exact same model in a boneyard. I did find the large gear new but I believe it is the same as a model that was sold in the US. My grey Yanmar has a lot nicer braking system and so the pinion gear/shaft are different. I did e-mail a gear rebuilder for trucks and heavy equipment, I'll see if I get a response, thanks all, bill.
   / gear rebuilding service? #5
Not all machine shops have the equipment for gear work. I'd start calling the machine shops in your area and ask for recommendations. If they have a dividing head and a horizontal mill they could get the specific cutters needed to duplicate the teeth on your gear/gears.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
1994 HONDA 300 FOURTRAX ATV (A51247)
1994 HONDA 300...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A53472)
New Lewis Brothers...
UNUSED RAYTREE RMSG29-29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
2018 Ram 5500 Chassis Truck, VIN # 3C7WRMFLXJG243968 (A51572)
2018 Ram 5500...
