etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,054
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Way back in 1979 I worked in a lumber mill as a machinist and one of my jobs was to rebuild gear pumps. This old guy who was their head machinist told me what had to be done. I had to flatten the end plates of the pumps by machining them There would be wear from the ends of the gears in the end plates and this would allow hydraulic fluid to flow past. So, after I machined away the pockets worn by the gears away I would check that the plates were flat and then reassemble the pump using new shaft seals.
Now I think the gear pump on my mid 1970s Case 580CK needs this same service. This is because when the oil is cold the tractor develops over 2500 psi but when the oil is warm the tractor is lucky to maintain 1000 PSI.
When I did the work on those gear pumps way back when I never checked the clearance between the gear teeth and the gear pockets. I know this clearance must be small but I don't know how much wear I can get away with.
Though just retired I still own a complete machine shop so I can do any machining needed.
So, can anyone here give me any guidance regarding gear pump rebuilding on this old machine?
Thanks,
Eric
Thanks,
Eric
