Gear Oil Question
   / Gear Oil Question #1
drjay9051
Morriston, Fl. 40 miles west of Ocala. More cows
Kioti DK 40 HST
Time for the 50 hour on my DK40HST. Not clear on front axle gear oil.
Manual calls for "SAE 90 gear oil or better, or same as T/M oil."
Two questions
By T/M are they referring to transmission? In other words I could use hydraulic fluid?
Secondly i found both 80W 90 and 85W 140. So is 85W 140 "better than" 80W 90? May be a bit thick for north Florida.
Any help is appreciated.
   / Gear Oil Question #2
if your manual is specing 80 or 90w fear oil.. then 80w90 should be fine.
PS. most tractors do not use plain hyd oil in their transmission.. but rather a multi purpose universal oil. UTF fluid etc..
   / Gear Oil Question
I was referring to tractor trans/hydraulic not straight hydraulic.
Any clue what "... same as T/M oil." is referring to??
   / Gear Oil Question #4
not familiar with your machine or specs so I wouldn't even hazard a guess as to what they are refering to.. that's why I'd stick to what they said previously.. IE. if they called out a gear oil spec.. at leas tthat you know you can dupe.. etc..
   / Gear Oil Question #5
I believe MT indicates that it is safe with softer metals
80/90 is ok
Two questions
   / Gear Oil Question #6
   / Gear Oil Question #7
My DK40 came with hydraulic oil (tractor fluid) in the front diff. My manual also stated gear oil, so I contacted the factory and they said that I can use either. I went with the hyd. oil to simplify things plus I hate working with and smelling gear oil. This was ten years ago and my front diff has never been apart...Mike.
   / Gear Oil Question
thanks for info.
I'm thinking the T/M refers to transmission.
   / Gear Oil Question #10
Multi viscosity oils are rated by their SAE weight at cold and at operating temperature. So an 85w 140 acts like an 85 weight in the cold, and when it gets hot it behaves like a 140.
You can use good old straight 90w in the front axle. I find it easiest to fill the axle by taking off the cap on the pivot housing (doesn't matter which side) and pouring it in.
Another trick is to get a pesticide sprayer and fill it with gear oil. You cut the spray end off the wand. After you pump it up, you stick the business end in the fill hole and pull the trigger. It often takes a long time, so you should plan to put a pan under the fill, wire the trigger open and come back every few minutes to pump it and check the level.
PALLET OF HITCHES (A45333)
PALLET OF HITCHES...
PORTER CABLE 150 PSI AIR COMPRESSOR (A45333)
PORTER CABLE 150...
2011 CHEVROLET SILVERADO 2500 (A45046)
2011 CHEVROLET...
2005 Freightliner M2 112 T/A Galbreath Roll Off Truck (A42742)
2005 Freightliner...
2007 BBB F40 STATION MANIFOLD TRAILER (A45333)
2007 BBB F40...
2019 SALVATION TRAILERS (A45046)
2019 SALVATION...
