Gear oil or hydraulic tranny fluid?
   / Gear oil or hydraulic tranny fluid? #1
redinrush
Rush, New York
Mahindra Max26
Just reached my 50 hours with a Max26 and time for filters and fluids. Twice in the owners manual it says the front axel fluid is hydraulic transmission fluid. Ok I guess thats what I'll use, but when the dealer looked it up, their computer lists 80/90 gear oil. Any suggestions other than not wishing to mess with my warranty?
   / Gear oil or hydraulic tranny fluid? #2
LOL! Welcome to the wacky world of the Mahindra manual. :mur:
   / Gear oil or hydraulic tranny fluid? #3
gear oil - but do not know the exact type off the top of my head. others said trans oil or trans if an emeregency and you need to top off.
dealer said gear oil!!!!!
   / Gear oil or hydraulic tranny fluid? #4
Ask the dealer what they put in it and select the brand you want. That won't cost one red cent. As far as the manual it is probably right if you could read Indian (I guess) but something got lost in translation to English. I have the same problem with an "Ansung" made tiller from Korea. Like BlackOps said "dealer said gear oil".
   / Gear oil or hydraulic tranny fluid? #5
Drain it and see what's in it now. There's no mistaking the smell of gear oil vs. hydraulic fluid. :)
   / Gear oil or hydraulic tranny fluid? #6
Any gears with high sheer loads or wet brakes/wet clutches? Some motor oils carry a gear lube spec on their label.
   / Gear oil or hydraulic tranny fluid? #7
hydro's - Hydraulic fluid
engine oil - 15w - 40 Rotella diesel oil
Front wheel oil - 80-w90 gear oil
that is what my notes say - dealer head tech told me this - i have a max 25 hst
   / Gear oil or hydraulic tranny fluid? #8
I think it was Dave's Tractor who said, the Mitsu made tractors should use hydro fluid. My 3016 Mitsu made manual says hydro. It came with hydro.
Your manual says hydro.
   / Gear oil or hydraulic tranny fluid? #9
this was provided by the head tech at the dealer. they work on mahindra all day so i am trusting him for the info.
   / Gear oil or hydraulic tranny fluid? #10
Dave's Tractor is a dealer and a former West Coast distributor, and perhaps the most Mahindra knowledgeable member of this forum.
My Mitsu made Mahindra came with UTF and that's what went back.
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53342)
THIS WILL BE A...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53472)
Kubota BX2680...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
40' CONTAINER (A51248)
