Oil & Fuel Gear oil foaming
   / Gear oil foaming #1
Farwell
Veteran Member
Farwell, Michigan
JD 2010
I changed out the gear oil in my Troy-Bilt tiller. The manual calls for GL4 85W-140 gear oil for the transmission. I have not been able to locate any GL4. Everyone I have talked to at the dealer where I bought the tiller, NAPA auto supply and Ag equipment repair said to use GL5 85W-140 so I took their advice. I drained out the old lube and filled the transmission to the overflow hole as stated in the manual. I used the tiller for about 15 minutes, shut it off and let it set for around 10 minutes so it would cool off. I removed the plug in the over flow hole and real foamy oil came gushing out, there must have been a cup or more of the foamy stuff. I checked the container that the new oil came in and it said that it was an anti-foam type oil.
Anyone have this type of experience? If so what did you do about it?
   / Gear oil foaming #2
You can use this stuff...
Amazon.com: Royal Purple Max Gear Synthetic Gear Oil 85W140 1 Quart Bottle: Automotive
   / Gear oil foaming
PaulChristenson said:
Thanks Paul,
I will do some research on the Royal Purple Max. It sounds like it should do the trick if I find that I need to go that way.
Regular GL5 85W-140 should work because it is just a tiller and the stress, heat and pressure is not close to what a truck or car rear end would put out. I am going to give the GL5 another try before trying anything else.
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 31'' (A53002)
NEW Wolverine Skid...
2020 JOHN DEERE 8R 250 LOT NUMBER 185 (A53084)
2020 JOHN DEERE 8R...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
