Gear lube for brush cutter-90w?
   / Gear lube for brush cutter-90w? #1
Slippy
Veteran Member
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
I have a new 10' cutter and need to fill gear boxes. Manufacture says use 90w oil. At the store, they sell 80w-90w and also 90w-145w. Which weight should I use? I checked at TSC and they sell Traveler. Is it a good gear lube?
   / Gear lube for brush cutter-90w? #2
<font color="blue">( 90w-145w ) </font>
...will operate at higher temps... but don't try to brush cut @ -30 below zero... go to the other flavor... /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif
Really, either would be fine, but I use the 85or90w145 for the extended/higher temp range... /forums/images/graemlins/smile.gif
   / Gear lube for brush cutter-90w? #3
I seen some manufactures recommend 85w-140 or OO ep grease. The 85w-140 will provide better protection if you run continously like 4-8hrs? if not i'd run 80w-90 till i had oil leaks then use 85w-140 or EP 00 grease..
John Deere 853 20ft Corn Head (A55301)
John Deere 853...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2000  INTERNATIONAL 3800 MID SIZE SCHOOL BUS (A54607)
2000...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
