gear issue in under 60 hours
   / gear issue in under 60 hours #1
PA hayseed
Platinum Member
The real central PA
nx5010 hst cab
Dealer made it right, pick up , fix up, and return in about 1.5 weeks, so this is not a "complaint thread".
Just wanted to post it so that others might use it for reference.
Was cutting my field, backed up under a pine, got stuck in reverse and couldn't go forward. Had to tow tractor out from tree and rode it in reverse up to the garage. Thought maybe it was a cable - nope. Some people on here have said that the petentionometer cables/solenoids can get water (bone dry at my place but checked that too). Looked for disconnected cables, missing pins/bolts, tried it in 4 wheel, and various other settings.
Dealer said that they had to split it and replace the hydraulic gear.
At least I got new fluid and filters out of the deal.
I can't say enough how much I miss my old tractor(if only it had a cab and less wear and tear). This fly by wire stuff seems like a mess. Less than 60 hours and has been in the shop twice.
FWIW
   / gear issue in under 60 hours #2
Did you press the dealer for what might have caused the gear to fail? Easy enough to replace a gear (relatively speaking), and all machines have some issues or bad parts straight from the factory, but it'd be informational to know why the gear failed in the first place.
43011 (A51691)
43011 (A51691)
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2014 Dodge 5500 4X4 Bucket Truck (A52748)
2014 Dodge 5500...
2014 DOONAN (CHAPARRAL) 502BBNHTTBZF 50FT CONESTOGA XP SPREAD AXLE FLATBED (A52141)
2014 DOONAN...
