Gear cover/crankshaft oil seal
   / Gear cover/crankshaft oil seal #1
dpauly
Bronze Member
Hertford Cty, NC
Branson 3120R
Greetings. Replacing the crankshaft oil seal located on the gear cover of a Kukje (Branson 3120R, 2011) A1500 engine. Anybody know if the seal should be driven only until outer surface is flush with the outside of the gear case (which leaves a gap on the inside of approx. 1/8" between inner surface of seal and bottom lip of the crank bore of the cover) OR, should it be driven until touching that 'bottom' (obviously recessing the seal's outer surface 1/8" lower than flush with the outside? (Personally I cannot see where it would make a big difference but there must be some reason it's that way.) Is there a rule of thumb for such situations? Thanks in advance.
   / Gear cover/crankshaft oil seal #2
Having a little leeway on that could help if you have a shaft that is scored from the seal. You should be able to tell where it ran based on the mark, even if it isn't scored, if it originally ran flush with the outside and setting it back can run on a smoother part of the shaft, go for that. Be sure and put a small amount of grease between the seal lips so it won't start out dry, will last longer and not as likely to cause scoring.
Of course if the shaft is bad enough to require a speedi-sleeve, it won't matter. I'd probably seat it all the way down so it was in more securely.
Another reason for seating it all the way might be for clearance on the pulley hub that goes on the shaft, you don't want that touching the seal when it's rotating.
Thanks, flyerdan. Your reply makes sense.
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
19200 (A50324)
19200 (A50324)
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
FRONTIER AH11G LOT NUMBER 112 (A53084)
FRONTIER AH11G LOT...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
