Mowing Gear Box SC 2400 Peerless H1050-013
   / Gear Box SC 2400 Peerless H1050-013 #1
MN farmer wanna be
SC2400
Anyone know where I can get parts for a Peerless H1050-013 gearbox? Apperantly Cub decided to discontinue it a year after I got it and now I have no idea where to get parts. I need the bearing, and seals going out the back side to the PTO shaft.
Sure glad I bought a heavy duty machine so it could break down often!:(
   / Gear Box SC 2400 Peerless H1050-013 #2
You might be able to find what you need here:
http://blackhawk.motorsportdealers.com/pages/oemparts?aribrand=CUT#/Cub_Cadet/Sc2400_(54A)%2c_54AEA4N-727%2c_54AFA4N-727%2c_54AGA4N-727%2c_54AEA4NO727%2c_54AEA4NP727%2c_54AEA4NQ727%2c_54AEA4NR727%2c_54AFA4NO727%2c_54AFA4NP727%2c_54AFA4NQ727%2c_54AFA4NR727%2c_54AGA4NO727%2c_54AGA4NP727%2c_54AGA4NQ727%2c_54AGA4NR727/Rear_Pto_Shaft/949P1207-A/949P12070098
Blackhawk Lawn and Power Equipment Inc. has a pretty nice parts look up section. If the link doesn't work, you can find what you're looking for by the following steps.
1. Blackhawk Lawn & Power Equipment - Parts, Sales, & Service
2. Hover over Parts On-Line
3. Click on Cub Cadet
4. From the Find Parts by Model, choose the following
First box/drop down = Cub Cadet
Second box/drop down = Cub Cadet Yanmar
Third box/drop down = Sc Series Compact Tractor
Fourth box/drop down = your tractor. This dropdown shows multiple Sc 2400's and Sc 2450's - I think the listing is by serial number.
Fifth box/drop down = The section of the tractor you are looking for. I believe you are looking for the parts for the Rear PTO Shaft.
Sometimes I use this site if I already know the part number and I'm just trying to get an idea of the price.
www.cubcadetpartsnmore.com
I've attached the PTO Shaft section of the Parts Manual. Let me know if this isn't what you need and I can get you the other pages. You can get the parts manual from here: Cub Cadet PDF Manual Web Archive
Enter in the model and either a 0 or a 1 in the serial number field and you should be able to get list of the operators manual and parts manual.
Hopefully this helps you find what you are looking for.
  • Page 83 from SC2400 parts manual PTO Shaft.pdf
  • Page 88 from SC2400 parts manual Rear PTO Shaft.pdf
   / Gear Box SC 2400 Peerless H1050-013 #3
I'm not familiar with the mower deck but after doing some searching online, I'm starting to think you might be talking about the gear box on the mower deck.
Here's a dealer locator from Peerless:
Dealer Locator
This looks like the specs on the gear box:
1050 Right Angle Drive Gearbox
Here is the breakdown on the MPK60RS Mid PTO Kit:
http://blackhawk.motorsportdealers.com/pages/oemparts#/Cub_Cadet/MPK60RS_Mid_PTO_Kit%2c_59A40014727/PTO_Kit/40014727-A/400147270002
Here is the breakdown on the mower deck:
http://blackhawk.motorsportdealers.com/pages/oemparts#/Cub_Cadet/MM60RSe_Mower_Deck%2c_59A40007727/Mower_Deck/76903639-A/769036390001
Here's the breakdown of the gear box. I think this is really what you are looking for.
http://blackhawk.motorsportdealers.com/pages/oemparts#/Cub_Cadet/MM60RSe_Mower_Deck%2c_59A40007727/Gearbox_Drive/76903639-A/769036390004
I'm sure you probably already have this but incase someone is looking for it, here is the manual for the mower deck:
http://www.gtrippleb.com/sc2400/59A40009727%2060%20in%20mower%20deck.pdf
   / Gear Box SC 2400 Peerless H1050-013 #4
It may be time for a new dealer as all those parts are available through Cub.
   / Gear Box SC 2400 Peerless H1050-013 #5
That was my though too. I find it hard to believe cub doesn't have these simple parts the OP needs.
Yes, new dealer is deffinatly in order, thanks everyone I think I found the part I need on it.
Dealer once again messed up as they gave me the new snow blower head, and neglected to refill the tranny case when the lines were hooked up.
2017 PJ MFG 40 T/A GOOSENECK (A50854)
2017 PJ MFG 40 T/A...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
1997 John Deere 8100 MFWD Tractor (A52128)
1997 John Deere...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
