Gear Box Leaking
   / Gear Box Leaking #1
LouieJunior
Platinum Member
Moline, Illinois
JD4052R Open Station
I have a very old, no-name Post Hole Digger with a leaking gear box. Are there firms that repair these type of things? -- or am I on my own. It wouldn't kill me to get a new PHD, but I use it infrequently and would prefer not to. Should I just let it leak and give it some grease before each use?
   / Gear Box Leaking #2
How about putting some Corn Head grease in it? Many gearboxes that have bad seals have that type grease installed in them
   / Gear Box Leaking #3
If you want to stay with oil then pull it apart and go to a bearing store. They will have seals and speedi sleeves. A speedi sleeve is a very thin metal sleeve that covers the worn part of the shaft where the old seal was rubbing against.
   / Gear Box Leaking
Thanks for the suggestions. The thing is so old and rusted, I'm not even sure I can get it taken apart.
   / Gear Box Leaking #5
I bet you'll be surprised how easy it comes apart. The threaded portion of the bolts most likely aren't exposed to the elements so they will be in real good shape.
6ft Pull Type Hydraulic Dirt Pan (A48837)
6ft Pull Type...
New/Unused Quick Attach Pallet Forks (A48837)
New/Unused Quick...
2022 CATERPILLAR 272D3 WHEELED SKID STEER (A50458)
2022 CATERPILLAR...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
2021 Ford Econoline Van, VIN # 1FDWE3FN7MDC03249 (A48836)
2021 Ford...
2018 Dodge Journey SE SUV (A50860)
2018 Dodge Journey...
