GC2610 will not fit bushog????
   / GC2610 will not fit bushog???? #1
Wacky
Veteran Member
West Virginia
2010 GC2610
I bought a 4' king kutter rotary cutter at the same time I bought my GC. I was told that it would fit. Yesterday I tried to mount it but the lift arms will not expand wide enough to accept the pins on the cutter, they hit the BH brackets.
Besides that when the 3pt is fully raised, it just lines up with the mount pins on the cutter:confused:. So I will not be able to lift off the ground. My question is does anyone else have this issue or is the cutter to large for the GC?? I went and picked up the MMM yesterday with the cutter still on the trailer and asked if it would fit my GC and was told it should. I think there should be a smaller one available 4' wide, that should work correctly. Am I wrong??
   / GC2610 will not fit bushog???? #2
Wacky, are the 3pt hitch pins on the cutter mounted inboard or outboard? If outboard, mount them inboard.
Even if I mount inboard, the lift is all the way up to line up with the mount pins, so I wouldn't be able to lift off the ground. I also would have to buy a very long 3rd link to reach as high as the mount is on the cutter. I think it is for a larger tractor not a SCUT.
   / GC2610 will not fit bushog???? #4
How about some pics for us to see.I have a gc2300 and I've moved my old 5' Howse brush mower around with it ,and it worked fine.I use that mower on the MF 175 to cut the rough areas with.I just use the gc2300 to move it around the yard and out of the way of grass cutting etc". The howse mowers 3pth pins are about 10-12" from the ground with tthe mower sitting on its own.How high off the ground are the pins on yours.I also have one pin mounted inboard and one outboard.I do this reason so that when the mower is on the MF 175 it'll sit more to one side.I also have a big spring that I mount to the 3pth arm on that side so it holds the mower over to that one side so that it makes it good for cutting right to the edge of trails and along fence lines. Measure how high your pins are and how high you 3pth ball socket ends lift off the ground post them and let us know.I'll go measure how high mine lift and see if yours aren't set in the right place.Larry
The lift pins are 19 3/4" and the 3rd link is about 42" from the ground. I don't have the camera today wife has it on her trip. Maybe post pics tomarrow. The links on the GC go up to about 20" off ground. The cutter is the same one King Kutter has on their website, and is assembled as such.
   / GC2610 will not fit bushog???? #6
You said the 3pt arms is hitting the BH bracket when lowered ? Is your 3 pt removeable ? if it is then it sounds like the lift arms is backwards.
   / GC2610 will not fit bushog???? #7
forgot to add, make sure the turnbuckles is loosened up all the more.
The Lower links hit when spread apart to try and slide over the mounting pins and the left link is stationary, no turnbuckle.
UPDATE.....
I called the dealer he said he sold a bunch of these for my size tractor. He said he would do some checking. Turns out, KingKutter changed the mount setup. He is ordering me an XB (which is more money and made specifically for SCUT) for an even exchange!:thumbsup: Feels good to have a dealer that will step up to the plate for a change:D! Thanks guys for all the help!
   / GC2610 will not fit bushog???? #10
Whacky I had the same problem with the same cutter on a Kubota B21. What I did was add another set of pins facing inward about 6 or 7" below the originals. Now for the life of me I can't remember if I drilled the holes or they were existing.
MarkV
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2010 International 4400 National Crane 300C Crane Truck (A50323)
2010 International...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
