GC2410 Torque Specs
   / GC2410 Torque Specs #1
Zewbie
Maine
2008 GC2410
Hi...I'm hoping someone might be able to provide the torque specs for the drain bolts (hydraulic, front axle, and oil. I recently purchased the tractor and the previous owner has the manuals in storage, so I won't have them for a bit but I'd like to do the 300 hour service.
Thanks in advance!
   / GC2410 Torque Specs #2
Don't know, never looked... I just use the "armstrong" method -- tight, but not too tight. Check for leaks.
Do, however, be careful with the plastic/aluminum fittings on the hydraulic intake screen located behind the tire, as well as when you put the filters on.. seems I stripped the threads on the first oil filter I replaced and had to get another. Very easy to get it cross-threaded. (No problems since, as I'm very careful with that.)
   / GC2410 Torque Specs #3
Thanks in advance!
Torque wrench, torque wrench, I don't need no stinking torque wrench! JK, never use one on regular maintenance items. Only time I use one is for high dollar items like engine blocks. But I understand you want to do everything right with your new to you tractor. If I have time I will look in the owners manual tonight when I put my Berco cab on for the winter storm tomorrow.
Hopefully someone can chime in for you before then cause I am unreliable when it comes to signing into the tractor forum.
That would be terrific! How do you like your cab?
   / GC2410 Torque Specs #5
Very nice, I love the simplicity of it and the fact that once you first mount it its so easy to take off and put back on when needed. keeps me warm and dry in the winter when snowblowing.
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
1997 John Deere 8100 MFWD Tractor (A52748)
1997 John Deere...
