GC2410 TLB bucket tooth
   / GC2410 TLB bucket tooth #1
truenorth
I looked at my CB05 bucket just now and one tooth is missing. I can find the part number but how do I install it? I've looked at various videos but they show a pin or set screw. I can't see any holes...
   / GC2410 TLB bucket tooth #2
You will have to weld it on, if\when I have to do the same I will weld the new tooth on. I do have a MIG welder, if you dont you can take the bucket off and bring it to a weld shop.
   / GC2410 TLB bucket tooth #3
Yeah, it wasn't until the next series of BH they went to the bolt-on teeth. I wonder if you can update the bucket if the weld-on tooth is tough to find..?
The tooth part you found is likely the bolt-on for the newer bucket. There may be some custom fabrication needed to make it work.
I have the same bucket and am designing a "clean-up edge" to bolt-on over the teeth for ditch maintenance work.
Wolverine Slide on Manure Forks (A50515)
Wolverine Slide on...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
Chery 7' 20 Drawer Workbench (A50121)
Chery 7' 20 Drawer...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
