GC2410 l, weird Left/Right turn signal blows 15 amp fuse
   / GC2410 l, weird Left/Right turn signal blows 15 amp fuse #1
cdaigle430
Veteran Member
Maine
MF GC2410
However the flashers do not, I followed the wiring back to the tailights but everything seems in order.
I dont really need them but I dont see why they shouldnt be working.
Have to hit the auto store for spare 15amp fuses.
   / GC2410 l, weird Left/Right turn signal blows 15 amp fuse #2
Flashers and hazards will use different relay. Also, different wiring from switch to relay
   / GC2410 l, weird Left/Right turn signal blows 15 amp fuse #3
check for corroded/broken wire going into turn signal relay, iirc it sits next to fuel pump shutoff relay (2 relays on right hand dash post) and is the one on engine side of post while pump is orientated towards seat side of post.
been long time but I THINK the wire in the bundle ( iirc 8 pin connector using 6 pins) that can easily cause this is white.
yeah...been there.
Im calling ut good for now. Never needed blinkers in 14 years. Need to remember that it will blow the 15 am fuse if i do try it. Next year when Im bored I will dive deeper.
   / GC2410 l, weird Left/Right turn signal blows 15 amp fuse #5
I drive on county road a lot on a blind hill so...meh...use them. but really, max speed 8mph...a person on a bike could pass me going uphill :)
   / GC2410 l, weird Left/Right turn signal blows 15 amp fuse #6
I believe the only time my blinkers have ever been on is when I hit the switch accidentally. I just leave the hazard warning light function on when I'm up near the road.
   / GC2410 l, weird Left/Right turn signal blows 15 amp fuse #7
Keep in mind the 12V+ is only half of a 12V circuit. A poor ground will increase total resistance too.
2000 Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2000 Lull...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2014 CATERPILLAR CB54 XW SMOOTH DBL DRUM ROLLER (A51242)
2014 CATERPILLAR...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
New Calf Hut (A50515)
