Gc2410 3 point won’t raise
   / Gc2410 3 point won’t raise #1
Mounter1977
Massey Ferguson gc2410
Hey I have a 08 gc2410 I removed my backhoe attachment to set up my three point and can’t get the 3 point to raise I did check the lock under the seat I’m good there was not sure if the three hydraulic lines that were hooked up to the backhoe needed to be attached to anything, I just bought the tractor so I thought someone could help me figure the problem out thanks in advance!
   / Gc2410 3 point won’t raise #2
Yes I believe you need to loop two of the lines together that went to the back hoe. Hopefully somebody familiar with Massey can tell which two lines.
   / Gc2410 3 point won’t raise #3
The lines have color coded marked connectors and need to be connected to get fluid through the system. Once you hook those 2 up you should be back in business.
   / Gc2410 3 point won’t raise #4
Yes you need to hook the lines back up somehow.
But most important....do NOT operate the tractor at this time. You are deadheading the pump and will destroy it if you operate it as is.
Do you have a manual for the tractor and/or backhoe? All this should be spelled out in the manual, so if you dont have one, I'd suggest getting it either from the dealer or previous owner.
   / Gc2410 3 point won’t raise #5
john deere 3025e rear lift arms stuck want lift
2016 CATERPILLAR 249D SKID STEER (A52705)
2016 CATERPILLAR...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2008 Ford F-250 (A55218)
2008 Ford F-250...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
