GC2400 & GC2410
   / GC2400 & GC2410 #1
northwoodpower
Bronze Member, Advertiser
NH
1552 CAB
If you are interested, we have the new tractors in stock at all our locations, Northwood NH, Enfield NH, & Hermon ME.
We do have a few GC2310's in stock also if you want to compare the two.
   / GC2400 & GC2410 #2
What are the difference between the 24 and the 23? Dealer in my country told me there's no difference in the power, is it right?
   / GC2400 & GC2410 #3
I got my 2310 from Rick @ Northwood Enfield, and have been out to his shop to look 'em over.... Yes, the same engine is in the 24 series, but some pretty slick improvements in ergonomics and controls. I particularly like the new dash, which is lighted, has a temperature gauge, and a much larger (easier to read) tachometer in the center. They also went from a single-pedal forward/reverse control to a 2-pedal setup. There's a link somewhere in this site that has some good photos of the 24 series. I'll stick with my 2310 and the 0%, however.... Perhaps Rick can answer other specifics.
   / GC2400 & GC2410
The GC2300 and the GC2400/2310&2410 use the same engine. Soon the GC2600/2610 will be available they will be the same tractor with a 25hp diesel engine. All implements are interchangeable with all the GC models.
I hope this is the info you are looking for.
   / GC2400 & GC2410 #5
Dang, are you serious about the 2610? I'm currious about the specs and estimated price vs. the 2310.
   / GC2400 & GC2410
I checked pricing on the 2310, 2410, & 2610. The 2410 is about $700.00 more than the 2310, and the 2610 is about $500.00 more than the 2410.
This will vary with rebates, discounts, etc. Hope this helps.
   / GC2400 & GC2410 #7
So, it has a bigger engine but, it's lift and load capacities are the same? Does it carry a larger hydraulic system? I'm currious what extra capabilities a larger engine is providing you.
That price jump is minimal and I'm not sure why one would buy a 2410 over a 2610.
   / GC2400 & GC2410 #8
It will most likely also have a higher volume pump.
DEWFPO
   / GC2400 & GC2410 #9
I think I missed out on somthing when doing my research. I opted for the 2310 over the 2410 knowing they were basicly the same machine and took advantage of the extra cost savings but, if the price for the 2610 is only $500 over the 2410 I now wish I would of waited.
Granted, I love my machine and it does exactly what I want out of it. I would of easily paid $1200 more for the 2610 to have that little extra umph. I hate it when things like this pop up.
   / GC2400 & GC2410 #10
The 23xx,24xx and 26xx all have the same motor. The difference is the max rpm for the 23xx and 24xx are 2600 rpm and the 26xx is 3000 rpm. Unless you run above 2600 rpm you will not tell the difference. If the pump puts out more it is more then likely because of the higher speed.
Doug
LANESHARK LS2 LOT NUMBER 159 (A53084)
LANESHARK LS2 LOT...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
