Dmacleo
Veteran Member
- Joined
- Sep 11, 2020
- Messages
- 1,969
- Location
- Etna, Maine
- Tractor
- 2010 MF GC2400 Owner, 2012 MF1532 User
mentioned in this thread.
www.tractorbynet.com
guess what I found missing this afternoon?
anyways massey does not list any part specs nor any adjustment specs.
its an M10x30-1.50 pitch.
odds are its the same on many GC series.
so I set bolt so just a touch of gap at full turn then touched housing with bolt. then did approx 2 full turns more so to keep cylinder off its internal stops. did that on both sides, side that stayed in was actually dead on I just had to use it as a pattern bolt so had to mark it and remove it.
edit:corrected spelling error and length error
Massey Ferguson GC 2300 bent steering box brackets :(
Hi everyone We have a GC2300 at our little pony club that has bent the steering box bent brackets that hold the hydraulic unit. I removed them, flattened them and reinstalled but it has done it again after a few hours use and actually seems worse. Can anyone explain why it might do this ? I...
