GC2310 Right Bucket curl Cylinder Leaking
   / GC2310 Right Bucket curl Cylinder Leaking #1
N1ST
Enfield, CT
Kubota B7800
My tractor has 26 hours on it and after runing it just a bit in the cold (40F), I noticed the right loader curl is leaking a little. Is this normal in the cold? Should I have it replaced or wait 'til Spring. I'm not sure if the local dealer will truck it in for service for free. Should I consider taking the cylinder off and bringing it in for repair or replacement?
   / GC2310 Right Bucket curl Cylinder Leaking #2
Any significant leakage is not normal. According to my MF paperwork trucking is not included in the warranty. Some dealers may provide it under some circumstances. I would talk to them before pulling anything. My dealer has sent a mechanic to my place before so I wouldn't have to haul it. If they want you to pull it off it should be a fairly easy job.
How about a tiny leak (a few drops) is that normal, or acceptable?
   / GC2310 Right Bucket curl Cylinder Leaking #4
If it squirts/drips every time you move the cylinder, it will most likely get worse. If you have quite awhile left on the warranty and are using it on a regular basis you could keep watching it to see. You really should never see drips around a properly working hydraulic cylinder, especially after only 26 hrs. Most likely a bad o-ring or a piece of contamination when assembled.
2002 Sterling M7500 Acterra Lift-All LA04C51 51ft Insulated Forestry Chipper Bucket Truck (A50323)
2002 Sterling...
2006 Ford F-550 4x4 Flatbed Truck (A50323)
2006 Ford F-550...
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
Honda EM7000iS 7000 Watt Inverter Generator (A50322)
Honda EM7000iS...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
Tradewinds Power Unit (A50121)
Tradewinds Power...
