GC2310 Removing Loader and BH
   / GC2310 Removing Loader and BH #1
todd92
Hunterdon County, NJ
Case Farmall 75A, Kioti NX5510HST, Kioti CK3510SEHC, Farmall M, MF GC2310 TLB
Is there a trick to getting the pins out? I have a very hard time getting the weight shifted just right to get them to slide out.
   / GC2310 Removing Loader and BH #3
I don't know about the BH but I have some experience with the FEL.
After lifting the Loader up and dropping the "legs", drop the FEL to the ground (Note: I cut a piece of 2x8 for the legs to set on so I just pull up to it). Tilt the bucket until the weight is off the pins and pull them. The rest is easy enough. Just try not to stretch the hyd. hoses.
I am sure someone will come through with the BH.
BTW: I mention setting the "legs" because my brother got a tractor the same time as I. When we talked about removing the FEL he said he had problems and used another tractor to assist in lifting the FEL off. I asked him if he put the supports down and he didn't know what I was talking about. Next time I saw him he said things went better the next time he removed the FEL. (Manual...We don't need no stinkin' manual)
   / GC2310 Removing Loader and BH #4
   / GC2310 Removing Loader and BH #5
Which pins are you speaking of, the Backhoe or the loader?
   / GC2310 Removing Loader and BH #6
Both the loader and the BH. I put the legs down and supported the weight with the bucket. Same idea for both ends, the pins bind in the holes.
   / GC2310 Removing Loader and BH #9
For the FEL, tilt the bucket to the spot that the pressure is off the pins. It is there somewhere.
   / GC2310 Removing Loader and BH #10
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
