Oil & Fuel GC2310/2300 FUEL FILTER
   / GC2310/2300 FUEL FILTER #1
67PLY
PENNSYLVANIA
MASSEY GC2310
Has any one tried to change a GC2310 fuel filter. It is mounted on left side outer frame below the step. We have a 2004 model. Book shows a picture of of fuel sediment bowl w/a paper cartridge inside. They also show air bleed tube. Mine has no air bleed tube. And my on/off/air(?) positions are different that what manual shows. Picked up a filter at dealer. Took one of the mechanics out to show him. The new models are made like mine. Also having trouble loosening the "threaded ring" that holds the sediment bowl on Any help would be appreciated.
   / GC2310/2300 FUEL FILTER #2
Mine is the same. Turned lever to the up position, carefully used channellocks on retaining ring, replaced filter cartridge and left ring a little loose, turned lever down, turned key on to run fuel pump to bleed air from bowl, shut off key, turned lever up and tightened ring, turned lever back down. Cranked right up.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
UNUSED AGT MCMRT14 STAND ON SKID STEER (A51243)
UNUSED AGT MCMRT14...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
2007 Toyota Corolla Sedan (A50324)
2007 Toyota...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
