loulblades
With all that has been going on I haven't had a chance to be here for awhile.
So now I come calling with a problem.
It was quite a shock for me when one day I turn the tractor key off and the engine doesn't cooperate. I suffocated the engine that day but after some research, found the push rod under the rubber boot on the fuel shutoff solenoid that I am currently using to shut down.
I then applied 12 volts to test the solenoid and it did shut down.
So now that brings me to the fuel shut off relay (the 10 second relay that pulls in the shutoff solenoid).
I have a parts manual but it is not clear to me which relay (there is no fuel shutoff relay that I can find) although I found the relay on the tractor that is located on the left side of the steering column support.
In the parts manual looking at Chassis - Switch System a relay is shown that I am inclined to believe is the fuel shutoff relay and has (ENGINE) under it (pg. 177).
Looking at Engine - Electric (2) - Switches, Solenoid & Relay (Pg. 54) I see a relay (part # 3710474M1) but I don't know if this is THE relay.
If anyone knows the part number for the fuel shutoff relay I would appreciate the feedback.
TIA,
Lou
TIA,
Lou
