GC1710 500 hour service
   / GC1710 500 hour service #1
Rocko
Connecticut
MF GC1710
Over the weekend I did my 500 hr service.
It took me about 5 hours on Saturday then on Sunday I changed the coolant.
Here's what I used:
Air Filter..WIX WA10428
Oil Filter..NAPA gold 1360
Fuel Filter..NAPA FIL3262
Hyd Filter.. OEM 6258877M91
Oil...........Rotella 15w40
Hyd Oil.....Permatran 821XL SynBlend
Grease.....TSC heavy Duty 3% moly
Coolant....Zerex G 05...50/50 premix
Everything went pretty smooth, I had almost nothing on the screen for the Tranny, cleaned it off with kerosene, o-rings were in good shape.
Fuel filter sediment bowl had some crud in it...cleaned it out with Kero, paper towels and a screwdriver. Put it back together, bled the line, she fired right up.
I clean the air filter and grease the tractor frequently throughout the year, in July I usually do another engine oil and filter change (15w40) then in October/November I switch to Rotella T6.
I used the small drain hose for the radiator and I took the block drain plug out, after it drained, I stuck a garden hose in the radiator. In a short while clear water came out of both drain locations. I removed the coolant overflow tank, rinsed it out and reinstalled it.
Reattached the radiator drain hose, installed the block plug.
I do have one ripped rubber boot on the steering arm, I plan to patch that with a rubber patch and glue.
I had everything in stock, just had to purchase the Permatran 821XL $105.04 for 5 gallons
Anyhow, everything went well, no problems.
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
2011 GLOBAL 130BBL VAC TRAILER (A52472)
2011 GLOBAL 130BBL...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
Electric Mobility Scooter (A51694)
Electric Mobility...
CAT 973 (A47384)
CAT 973 (A47384)
