3-Point Hitch GC1705 - 3 Point Height
   / GC1705 - 3 Point Height #1
Massey2019
Fox Island WA
Massey GC1705
Purchased my GC1705 with loader and 54 deck, cannot be much more excited.
I bought a 3 point receiver adapter that is great. It mounted with no issues.
My question: how far down will the 3 point go? Is it limited by having the mower deck attached?
Mine will only drop to about a 35 degree angle, not all the way down.
Sorry, for the question, but have never had a real tractor.
   / GC1705 - 3 Point Height #2
MY 1715 will let the 3PH go down to about 8 inches off ground... And only has about 18 inches of vertical travel (I think)... I have been wondering if 3PH will actuality lift a mower high enough for real maneuvering....
If you are going to be changing implements a lot, you might want to consider a quick hitch....
And for any heavy lifting with FEL either use a mower as counter balance or make a ballast box.... I made about a 500-600 pound ballast box for rear and it made it much better/safer for FEL heavy lifts...
Also for some some odd shape lifting (things the refuse to stay in bucket) with FEL you may want to consider some bucket hooks...
https://www.tractorbynet.com/forums/customization/404148-bucket-hooks.html
Dale
Appreciate the information, will call the dealer tomorrow as there may be an issue with the tractor.
   / GC1705 - 3 Point Height #4
Just wondering if your top link is adjusted properly, or your pto shaft for your implement is the correct length?
Well, to be honest, I have never owned a tractor with a real 3 point hitch. My last was a John Deere 318 and it didn't have a 3 point.
I wondered if I should adjust the top link but am not sure if the geometry.
At this point, nothing attached except a 3 point adapter that I want to use to hook to my wood chipper.
Thanks,
   / GC1705 - 3 Point Height #6
Is this 54-inch the mid-mount or a 3PH mount? If you have a mid-mount mower attached, the 3PH will continue to drop its full travel range even after the mid-mount is sitting on the ground. You may need to adjust the pressure relief/drop speed knob (between your feet) to allow the arms to drop under their own weight when nothing is on them. Otherwise, hold the 3PH lever down while pushing on the right side lift arm with your foot.
If you're having a 3PH issue with a mower, the geometry is usually that: while on flat ground, the lower link pins and top link pin hole should be in a straight vertical plane. Shorten or lengthen the top link to start off and then adjust according to your grounds.
Got it working! There was a bracket at the top link connection, that was limiting travel down. I removed it and everything works fine. Not sure what this bracket is for, other than to maybe stabilize the 3 point setup when not being used?
The mower is a 54" mid mount on this unit. I checked mounting geometry and it seems to be correct.
I really appreciate you taking the time to respond, it helped!
Thanks,
   / GC1705 - 3 Point Height #8
The bracket is probably the one that holds up the top link when not in use, sometimes it will sit in a halfway position and hinder the top link from being able to go all the way down.
Just got feedback from the dealer and it is meant to stabilize the top link. Guess it must be new as they had to do some research and it wasn't in the manual.
   / GC1705 - 3 Point Height #10
Picture of what you're talking about?
2005 Ford F-250 Crew Cab Pickup Truck (A46684)
2005 Ford F-250...
2025 Safety Basket Forklift Attachment (A46683)
2025 Safety Basket...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE DAY CAB (A50046)
2020 FREIGHTLINER...
John Deere 7000 Corn Planter (A49251)
John Deere 7000...
1998 Express Trailer 14ft T/A Concession Trailer (A46683)
1998 Express...
2010 Chevrolet Silverado 1500 Pickup Truck (A46684)
2010 Chevrolet...
