GC1700 Series Snowblower Width
   / GC1700 Series Snowblower Width #1
Langanobob
Reno, NV
AC HD6G, Ancient Kubota HK5 Mini Excavator, MF GC1720
I知 looking at a used 63 wide front mount PTO snowblower for my GC1720. The blower is from a larger 30HP compact tractor and I will have some adapting and fabrication to do on the mount. I知 a little bit concerned about the blower width. It is a foot wider than the 登fficial MF2360 blower and also the snow blower guidelines in the snow removal section recommend not getting a blower wider than your tractor. We get heavy Sierra Cement snow here and in addition to HP I also have a concern about maneuverability and weight. Sounds like I might be trying to talk myself out of it!
Anyone have any comments or suggestions?
Thanks,
Bob
   / GC1700 Series Snowblower Width #2
If it was any easy hookup I’d say try it. But my guess is that it will be too much, especially since you have a lot of wet stuff. I’d pass on a lot of fabrication and find something else.
   / GC1700 Series Snowblower Width #3
Extra width is helpful around curves. I have a circular driveway with granite cobble curbing, and the 50" blower is kind of a pain to follow the edge. If you don't have curves, adapting the larger blower is probably not worth the effort. I think you'll be OK power wise, but will have to slow down as the snow gets deeper obviously.
Weight wise, I think the 50" is a little light. I got my 1720 in the winter and immediately put the blower on. Not having my tiny shed rearranged for the extra implements, I left the backhoe on for ballast, that was a mistake. The front end bounced dangerously. I've since used my ballast box, with a little weight removed, 300lbs seems pretty good. I don't think you'd have any issues even if the blower you are looking at is double the weight...just ballast appropriately.
One thing to check: Is the blower you are looking at made for the same mid PTO speed (RPMs) that the GC1720 provides?
Thanks for your comments. Fiziksgeek, yes, as near as I've been able to determine it's made for a 2000 RPM PTO. It has a chain drive reduction so I'd be able to make relatively small RPM adjustments.
   / GC1700 Series Snowblower Width #5
One other thought, I recall that the kubota blower and Massey blower were very similar but their rotation was reversed which surprised me so on this blower you are considering you may want to check rotation compatibility.
Wow. Never considered a rotation difference. Would be a classic case of Murphy’s law. I’ll check. Thanks!
   / GC1700 Series Snowblower Width #7
There is a guy on youtube who has a 68 inch mounted to his GC1710, cant get to it to post a link now because Im not allowed at work. It works very well, he even has a Bernco cab...
Thanks. I’m sure I can find it.
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
Toro Z Master 2000 Zero Turn Mower (A50322)
Toro Z Master 2000...
