GC1700 series plowing and general capabilities vs an old Yanmar 1802D?
   / GC1700 series plowing and general capabilities vs an old Yanmar 1802D? #1
Chadd
Yanmar
Thinking of finally replacing my old Yanmar 1802D with something a bit newer.
The 1802D is kind of an odd duck size wise, I consider it between a modern compact and subcompact. It is 4wd ~21hp 18hp pto and weighs in at around 2200#, I have a Koyker 110 loader on it. I am just wondering if the GC series will have the same capability as the 1802D as the GC seems a bit on the small side when compared size wise to my 1802D
I use the 1802D for yard and large garden work, pull a 2 bottom plow, 6' disk, 4' tiller, lift/move all kinds of stuff with it, and occasionally box scrape, and dig post holes.
Just wondering if any 1700 series owners could give me some input on whether or not the 1700 would be a good fit for me based on what I listed above. Also worth considering is I would like to use the next tractor I get for mowing ~3 acres also. I currently mow with Cub Cadet M72 tank zero turn and I am just getting tired of getting stuck with it all the time and it is a rough ride.
Thanks,
Chadd
   / GC1700 series plowing and general capabilities vs an old Yanmar 1802D? #2
I have a 1705 with a box blade. I used it to shave down knobs in my yard to prepare it for seeding. I could have dirt boiling over the sides of the box blade and it pulled it just fine. The occasional root would stop me but you will have that. I also have a 4ft tiller that I use and it manages that great. I think i could have gotten a 5 footer but my garden isn't that big. I use it for cutting wood, moving stone and spreading dirt as well as my primary mower. I think you would be happy. I am very pleased with it. Go test drive one and report back with your thoughts
Thanks for the feedback, any idea how a 1700 would do with a 2 bottom plow?
   / GC1700 series plowing and general capabilities vs an old Yanmar 1802D? #4
I would think there would be more drag pulling a full box blade of dirt with the tines in the ground over the two bottom plow. I don't think you will have a problem with it especially if you're current tractor pulls it.
We have a Massey dealer just about a mile down the road but he doesn't currently have any GC1700's in stock, I think I am going to stop by tomorrow and see if he has any coming in soon or if someone local has one I can try out. I will let you know how it works out.
   / GC1700 series plowing and general capabilities vs an old Yanmar 1802D? #6
It will not. The yanmar is heavier. The GC will do somethings better, but it is not as much tractor
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
