Wacky
Veteran Member
Alright, almost time. I just had a few questions regarding the procedure. I plan on taking my rear wheel off to access and inspect the suction filter. Where is a safe place to jack up w/o damaging the soft cast. I thought the hitch would be safe. And to empty and refill the front axle, if I remove the 2 vent plugs, refill cap and drains. do I need to jack one side of the axle to get everything out? Should the tranny and axle be warm like the engine or does it matter? Does 90w gear oil put extra pressure on the axle seals when cold or hot? Thanks guys for you input. I am planning on going with Permatran in the tranny not sure about the ft axle yet. I am going to purchase the oil, Fuel filter, trans filter and oil filter this week and maybe do this upcoming weekend:thumbsup:.
