GC 3 point hitch questions
   / GC 3 point hitch questions #1
rossn
Denver, CO
Massey Ferguson GC1705
I'm new to using a tractor with a 3 point hitch and have a few questions, as it pertains to the GC's (have a GC1705).
1. if I go across a water ditch will the hitch allow the implement (a pine needle rake, in this case) raise up as I go up the ditch?
2. Is it safe to hold the hitch raise/lower in the 'lowering' position, such that the rake will always stay on the ground regardless if the tractor goes slightly up/down?
3. Is there a true 'float' setting for the hitch where it always floats up and down?
Thanks!!
   / GC 3 point hitch questions #2
You can leave the lever in the down position. It has no down pressure. It will float in that position.
Thanks. On my GC1705, it has a spring return to 'neutral' on the lift control. Is there a way to lock the lever down?
   / GC 3 point hitch questions #4
The GC series uses a quarter-inching valve, which is why it has a return spring. It holds/floats in every position as there is NO downforce, only gravity or lift. If traversing a ditch causes the implement to be lifted by the ground, that will not change the hold position of the 3-point (full down). As you come off the grade, the implement will remain in contact with the ground and not remain up.
   / GC 3 point hitch questions #5
I purchased a spring loaded lever used on the John Deere 1025r to hold the lever down, $20 and works like a dream.
   / GC 3 point hitch questions #6
I opened a thread about this very subject, you might want to read it, there is a picture of the lever I speak of, do a search for "how does my three point hitch work", I would just add the link but I am unable to with my phone.
Thanks, all
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
John Deere S780 Combine (A53342)
John Deere S780...
TRUCKING INFO (A50775)
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
