GC 2310 power steering not working
   / GC 2310 power steering not working #1
twaugh
Massey Ferguson GC 2310
Hello,
New member here. I recently purchased a 2006 GC 2310 for a good price however the steering is very stiff and it does not appear the power hydraulic system is working. I have done lots of research and am a mechanically inclined guy but I am new to hydraulics. My questions may be a bit more simple so really hoping you guys can help shed some light on a few things for me.
I did find this thread:
Some things I have noted so far:
  • Steering physically works but is hard to turn
  • The steering wheel is sloppy, no doubt from it being used as a handle to mount the tractor
  • There is evidence of a leak when viewed from the battery side underneath. I can not see exactly where it is/was leaking
  • I understand there is a seal kit you can order to rebuild the orbitrol/column
  • There are 4 lines attached to the orbitrol
  • I believe the power steering has been broken for a long time
Some questions I have:
  • Is there a place to add steering fluid?
  • How do you test the orbitrol?
  • Is there a place to reference a parts schematic for this machine?
  • Anything else I should be aware of before tearing into this?
If there are a few threads that I missed to read please feel free to link them.
The tractor also had a hard start condition and after some basic troubleshooting I figured it was a bad ground somewhere. I did some searching and found a few threads on this site which pointed me to the ground cable up front. The cable was very frayed so I replaced it and success! The starter rolls over much faster now and the tractor starts within 2 seconds every time. Wonderful feeling!
Any help is greatly appreciated!
-Ty
   / GC 2310 power steering not working #2
Might go to AGCO site and lookup parts/repair manual for this machine.... Use "guest" login whenever possible....
Would suggest purchasing "Shop Manual" for machine to help with these sort of problems....
IF machine is hydrostatic drive (transmission) most likely the hydraulic power for steering is part of the power output from pump in hydrostatic transmission.... Two places I would consider first, the orbital valve under steering wheel and hydraulic cylinder on front axle....
Dale
Thanks for that link Dale!
   / GC 2310 power steering not working #4
There is also a MF forum where you might get a more direct response from some one with the experience with same problem as you are having....
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
Charlotte County (A50323)
Charlotte County...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
2020 McLanahan 150 TPH USP Sand Plant (A52377)
2020 McLanahan 150...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
