GC 2300 Tandem Disc Opinions
   / GC 2300 Tandem Disc Opinions #1
SirMatthewT
Massey Ferguson GC2300
I'm looking to pick up a small tandem disk for the GC 2300. I've compared specs with the Kubota BX's and their Land Pride implement matching chart and it appears that the GC 2300 should be able to handle a disc up to 60" with 16 blades and weight of 500-600lbs. I would prefer a 4' 12 blade disc. It just seems to match the tractor better width and weight wise and the 12 blades coupled with really not that much less weight gives better downforce per blade than the 16 blade 5'. I also worry that the GC 2300 will struggle to pull the extra 4 blades through the soil. However, I found a used 5' Lindley disc for sale for less than half of the price of a new Land Pride, Frontier or Woods 4' that is located about 5 miles from my place, which would be MUCH more convenient than the 100+ miles I'd have to haul a new one. I'd never heard of Lindley, but the disc is built much like the aforementioned brands' discs with the adjustable gang pins in the center. I have no idea what it weighs but I'd guess it's comparable to the Land Pride DH1060 (550lbs). Looking for opinions as to whether the GC 2300 will reasonably handle a 5' disc like the DH1060 or whether I should wait to find a 4 footer. and haul it down to the place.
   / GC 2300 Tandem Disc Opinions #2
Massey Ferguson GC2300 Dimensions​
Massey Ferguson GC2300 tractor photo
2005 - 2008
GC Series
Sub-Compact Utility tractor
Iseki built
Series:GC2300
GC2400
Massey Ferguson GC2300 Tires
Dimensions
Wheelbase:57.1 inches
145 cm
Length:97.6 inches
247 cm
Width:45.8 inches
116 cm
Height:72.8 inches
184 cm
Shiping weight:1,367 lbs
620 kg
Ground clearance:6.9 inches
17 cm
Page information
Last update:April 15, 2020
Copyright:Copyright 2020 TractorData LLC
Contact:Peter@TractorData.com
   / GC 2300 Tandem Disc Opinions #3
I own a GC2310. The reality is, it's a sub compact.
It's capable, but it's size is it's biggest limitation.
Whether it's worth trying to pull a disc with it or not, has not been answered here as far as I remember.
I'm guessing a tiller would be a better option.
Please let us know what you find out.
   / GC 2300 Tandem Disc Opinions #4
Disc Harrows behind subcompact tractors are suitable for preparing kitchen gardens with friable soil for seeding every year.
Measure the max spread of your GC2300 Three Point Hitch, Lower Links. Spread dimension is likely 20", like most SCUTs.
Most ( not all ) 5' Disc Harrows will have Lower Link pins spaced 26" apart.
A PTO-powered, forward tine rotation roto-tiller is a better soil mixing option behind a subcompact tractor.
VIDEO:
Behind a subcompact tractor, with its small wheels, the Disc Harrow and the tractor operator in the video would bounce around much more.
SPECIFICATIONS: XTreme Duty 48'' width Compact Tractor Angle Iron Disc Harrow
Weight with 12 X 16" diameter pans, as in video = 320 pounds.
320 pounds likely an absolutely max Disc Harrow load for a GC2300.
   / GC 2300 Tandem Disc Opinions #5
I should perhaps clarify a little more what my goals for the disk are. Primarily, I'd use it for breaking up small areas or strips of soil in buffalo grass pasture in late winter or early spring to promote native forb growth, weeds basically, such as ragweed and other seed bearing and canopy providing forbs for quail and ground birds. Buffalo grass is great forage for cows, not so great for much of anything else, jack rabbits maybe. I would be, I guess, preparing a seed bed of sorts, but I'm not planting a garden, essentially my goal would be to loosen the soil enough so, that for a time anyway, the native forbs can germinate and outcompete the short, tight prairie grass in strips close to cover. We also sharecrop out a small field that is normally planted to sudan "haygrazer" that's cut in the fall and it would be nice to be able to disk a few food plots along the margins of the field in the fall after the hay's been cut. I picked up the used GC 2300 a few months ago to mow around the cabin, keep the parking area and roads around the cabin passable and to smooth out the dirt pads around the stock water tanks from time to time. It works well for these tasks and fits very nicely in the sealed up shipping container I use for an "equipment barn" at ranch. I realize it's not a farming machine by any stretch but if possible I would like to be able to put it to use to help with some pasture habitat improvement. I think it's small and nimble enough to work in some of the tighter places I'd like to work if I can find suitable equipment for it.
Kubota "performance matches" the Land Pride DH1048 to the BX1880 which is an 18hp machine, weighing roughly the same as the 22.5hp GC 2300. The DH1048 weighs 420lbs and has 12 disks. Kubota matches the 5' DH1060 to the BX2380, a 23hp machine that outweighs the GC 2300 by about 80lbs. The DH1060 weighs 549lbs. The stated rear lift on the GC 2300 is way higher than either Kubota, almost double the BX2380. I realize that the rear lift number for GC 2300 is largely a moot point given that the tractor itself weighs less than 200lbs more than the stated lift capacity, simple physics there. Tarter's subcompact disk is a 5' with 16 disks which weighs roughly the same as the Land Pride 4' with 12 disks. The Tarter (or similar) 5' angle iron subcompact disk or the Land Pride (or similar) 4' box frame disc weigh roughly the same and are clearly the most ideal. The seller of this 5' Lindley disk pulls it with a Kubota L2501, which is not significantly more powerful than the GC 2300, but it is significantly heavier. So, my question is, would I, literally and figuratively, be spinning my wheels with the 5' box frame 16 disc harrow, or is it worth a shot to save $400-500 and a 100 mile or so haul to try it?
I will add that the GC 2300 currently has turf tires, which I'm not crazy about and probably need to change.
I do suspect that for breaking new, undisturbed ground for food plots with a good seedbed that a tiller would be clearly be the way to go since the the GC 2300 is really more of a "garden tractor". I don't think I'd really want to try to plow with it, even though Tarter and everythingattachments do make a subcompact turning plow.
VIDEO:
You're point about the bouncing is well taken. The subcompact bounces around a s@#*ton doing just about anything.
   / GC 2300 Tandem Disc Opinions #9
The TPH Lower Links on a Kubota L2501 open to 26".
Most 60" Disk Harrows have the Lower Link pins spaced at 26".
I am guessing that max spread of Lower Links on your GC2300 is 20", but I may be incorrect. If GC2300 Lower Link spread is only 20" it will not fit an implement requiring 26" spread.
MEASURE GC2300 LOWER LINK SPREAD.
MEASURE THE LOWER LINK SPREAD ON THE LINDLEY.
MEASURE THE PAN DIAMETER ON THE LINDLEY.
IF THE LINDLEY HAS AN ANGLE IRON FRAME AND 16" DIAMETER PANS YOUR GC2300 MAY PULL IT. IF THE LINDLEY HAS 18" DIAMETER PANS IT WILL LIKELY BE TOO HEAVY. ALSO, WITH ONLY 7" OF GROUND CLEARANCE THE GC2300 MAY WILL NOT BE ABLE TO PICK UP THE LINDLEY SO LINDLEY CLEARS THE GROUND.
A TPH mounted Disc Harrow extends far to the rear of the tractor. Leverage works against the tractor making effective weight of Disc Harrow heavier than the spec weight.
   / GC 2300 Tandem Disc Opinions #10
"Primarily, I'd use it for breaking up small areas or strips of soil in buffalo grass pasture in late winter or early spring to promote native forb growth."
Consider a Disc Plow, which is two or three pans from an Offset Disc, a Primary Tillage implement. I have no experience with Disc Plow reference following but Turf Pride brand is the only Disc Plow marketed for subcompact tractors.
Will Turf Pride work for you? I do not know. But what you want to accomplish is Primary Tillage.
LINK: Disc Plow | Turf Pride USA
2020 Massey Ferguson RB 4180V Round Baler (A50774)
2020 Massey...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2018 Ford F-550 Truck Altec AT40G 40ft Insulated Bucket Truck (A50323)
2018 Ford F-550...
2009 Ford Flex SE SUV (A50324)
2009 Ford Flex SE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
