GC 2300 hydraulic issue
   / GC 2300 hydraulic issue #1
Rickek
Greenville
2006 MF GC2300
So the other day when I was mowing the lawn, I had a couple instances where the power steering got hard to turn and it sounded like the MMM was spooling down for a couple of seconds. It happened 3 times in about 10 minutes s, self resolving. Grass was not at all tall, problem not even enough to cut it. I checked the sight glass and it was full verified by using an incline. I don't know when it was changed last, as I purchased used (800 hours showing). The transmission felt pretty hot when I checked it, HST fan is fully operational with no missing blades. It hasn't done it since. Thoughts?
Thanks!
   / GC 2300 hydraulic issue #2
The MMM runs off the motor, so, if it slowed down, it could be the engine.
You could start by changing the fuel filter.
Since you don't know the maintenance history, you should change the transmission oil, and filter. As well as remove, and clean, the pick up screen behind the left wheel. None of which may have any effect on the problem. But, at least you can rule some things out.
I've got the manuals on order, my first order of business is to check those items. It came from a Massey dealer, but no warranty other than everything works as it should. It had the oil, and oil+air filter changed along with new blades.
   / GC 2300 hydraulic issue #4
I have never used the mower deck, not sure how it affects the engine speed. The HST pedal gives max torque when depressed slightly. Pushing it all the way forward can increase speed, but also drastically reduces the torque from the HST. If you're in high range and going up an incline, it is possible to get to the point where the tractor will not move, and the engine starts to bog. This I have experienced.
Dennis
WOODS RC60.20 LOT NUMBER 88 (A53084)
WOODS RC60.20 LOT...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
