GC 1720 joystick question
   / GC 1720 joystick question #1
jkmfarmer
Farmall C
I bought a used 2018 GC 1720. I noticed the joystick seems a bit 'sloppy' compared to other tractors that I've used. The joystick runs thru a hole in the side of the tractor body with nothing supporting it but the rubber dust cover. I can't find a diagram to see if anything is missing. The joystick seems to work fine. Can anyone advise if this is the OEM set up or if something might be missing? Thanks....jkm
   / GC 1720 joystick question #2
Did I miss a picture? I can't see it.
Looked a couple of others and the stick looks unusually long. It probably will have a lot of play at the end.
   / GC 1720 joystick question #3
Actually that is the way it is.... Its supported by the valves/spring in hydraulic unit body and just hangs out there, boot is for pretty...
Sorry, I didn't include a photo. I thought it might be correct. The guy I bought the tractor from seemed like the kind of guy who took pretty good care of his equipment and I couldn't see him not replacing something that needed it. Thanks for the replies.....jkm
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2014 Dynapac CC4200 Tandem Vibratory Roller (A51039)
2014 Dynapac...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2014 CHEVROLET SILVERADO (A50854)
2014 CHEVROLET...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
