GC 150Z 60" chinese finish mower,gear oil,grease?
   / GC 150Z 60" chinese finish mower,gear oil,grease? #1
kbone1
St.Augustine, Florida
JM 354
GC 150Z 60\" chinese finish mower,gear oil,grease?
The gear box on my finish mower has a filler bolt on the top
side of it. When I looked in it you can see grease, Should I add gear oil and top it off? There is no grease zirk fitting on it, but there is also no drain on it either. If I add gear oil I will not be able to drain it out. So is that to tell me I should only pack grease in through the filler bolt? Is anybody familiar
with these things?
Thanks,
kbone1
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51691)
2015 Ford F-550...
2025 CFG Industrial 680 (A50123)
2025 CFG...
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53473)
Ditch Witch 6510A...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
