Gauges/Meters
   / Gauges/Meters #1
Anonymous Poster
Epic Contributor
In reference to a YM1500.
Can the idiot lights for temp and oil pressure be replaced directly with gauges? If not, what is the procedure if any?
Where can I obtain a new RPM/Hour meter combo gauge?
   / Gauges/Meters #2
This isn't YM 1500 specific but gauges and lights use different sending units. The senders for lights are basically limit switches and the senders for gauges are thermistors, they vary the resistance through the range. If you are going to add gauges you might as well go with mechanical units, they are more dependable.
   / Gauges/Meters #4
I put gauges on my 1500D. I use the gauges you can get at any auto supply. You will need the adapter kit that you can get with most of these gauges. However, nothing worked for the temperature gauge. I ended up getting a hydraulic fitting that would thread into the block. Then I drilled it out to accept the temperature sensor and used teh J&W weld for radiator systems. I've had it in place for over a year with no problems.
Larry
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2019 GENIE GS-1930...
1990 LOAD KING BELLY DUMP (A53843)
1990 LOAD KING...
2015 KENWORTH T800 KILL TRUCK BOBTAIL (A53843)
2015 KENWORTH T800...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2009 Yamaha Golf Cart (A52377)
2009 Yamaha Golf...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
