Gauge problems
   / Gauge problems #1
Clavin48
1999 new holland 545d
Hi all,
Long time listener first time caller. So I’ve recently upgraded tractors in a sense. I sold my 2011 Kioti ck30 and bought a 1999 New Holland 545d. I needed a bigger machine for snow removal and such and was spending too much time and asking too much of the little Kioti. I did love the machine a would have kept it if I could have afforded to keep both. My current problem is with the gauges. The tach swings back and forth quit a bit which isn’t a big deal cause you get a general feel for where it’s running during use. The temp gauge however seems to come up into the top of the green area very quickly and will stay there at idle no issue but climbs into the red very fast although the machine does not apear to be running hot or acting any different. I’m think about wiring in a generic auto temp gauge if I can to see if it says anything different. Just wondering if anyone has any tips on somewhere else to start? Thermostat maybe? Not sure what the regular operating temp should be to start with. Sorry for the lengthy post. Thanks in advance.
   / Gauge problems #2
Welcome to TBN.
The tach has dirt in the gauge between the two discs. If you take it out, you might be able to clean it and settle it down.
Is your radiator and oil cooler clean? The air cleaner swings out on that year and should be able to inspect. The thermostat could also be your problem, but without an accurate reading, you are just guessing that it is too hot.
The temp gauge on these is not real accurate, so you need to take a reading on the thermo housing or top hose with an infrared thermometer to find out if you have a problem or where the problem might be.
Also, if yours is a 4wd, make sure you grease the axle rear pivot and make sure there is plenty of oil in the front axle.
   / Gauge problems
Welcome to TBN.
Thanks for the tips I’ll checks those things first then. I just got the thing so I’m still learning how everything works but I’ll get there.
   / Gauge problems #4
Those gauge cluster are **** wiring is most always hard and crumbly
Tac runs off cable
Can buy cluster on eBay
2011 PROCO 130BBL ALUMINUM VAC TRAILER (A53843)
2011 PROCO 130BBL...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55301)
2023 NEW HOLLAND...
2015 MACK CXU (PINNACLE) (INOPERABLE) (A53843)
2015 MACK CXU...
2021 JOHN DEERE 624P WHEEL LOADER (A52705)
2021 JOHN DEERE...
Toro Mower (A50324)
Toro Mower (A50324)
