Gator XUV Recall!
   / Gator XUV Recall! #1
claykin22
Bronze Member
North Central Indiana
JD 3720, JD Gator XUV 620i
Last Wednesday I recieved a call from my dealer that I needed to bring my 620i XUV into the shop for some recall work. Unfortunately there wasn't anyone in the service department when I dropped it off to explain what was being recalled.
Apparently all of our complaining about a rattling noise in the front end has not gone unnoticed. I was told they had to check the torque on two bolts on the front differential because some had been loosening up and leading to problems.
Anybody else get this call?
   / Gator XUV Recall! #2
I suspected this was coming. Glad they are getting it done.
I don't believe all XUV's have the problem but it's best to check~!
   / Gator XUV Recall! #3
I have a 620i on order that might be arriving at the dealership this week, but based on the timing I would assume the factory should have taken care of this already....
   / Gator XUV Recall! #4
As far as I know it is NOT a recall, but a service notice.
I have the rattling noise but have not had time to get it addressed by the dealer. They contacted me too, but did not call a recall.
The fix is a simple adjustment on the front diff.
The noise is a nusiance noise, not a problem that will affect the durability of the diff.
Newer XUVs already have the proper adjustment from the factory.
   / Gator XUV Recall! #5
Complaint or Symptom :
Factory: John Deere Horicon Works
To: All C&CE Independent Dealers (Worldwide)
All AG Dealers (Worldwide)
Attn: Sales Manager and Service Manager
Date: 4 October 2007
Subject: JD Sales: Stop Sale Notice for Certain XUV and HPX Utility Vehicles Note: Region II is only involved with the HPX. The XUV is not yet sold in those markets. Issue: Potential for front brake calipers to be incorrect.
To: JOHN DEERE DEALER OF RECORD
Effective immediately, please do not sell, demonstrate, or deliver machines from the attached list.
A PIP will be published on or before 8 October to address this situation. The PIP will have Dealers inspect calipers (front and rear on XUV, only front calipers on HPX) and identify machines that will need to have calipers replaced.
Machines may be released from this Stop-Sale upon successful completion of the inspection procedure (which will be the first step in the PIP when announced) located on the second page of this document. Please be aware that as we gear up for release of the PIP, parts will not be readily available. Keep track of the units you inspect prior to PIP release. Identify those units that need calipers replaced and quarantine. When the PIP is released, complete any caliper updates that are needed and file the claim per PIP bulletin instructions.
If you have questions prior to PIP release, or have a retail sale pending, please enter a DTAC case through Pathways for additional information, if required.
Please share this document with your dealership General Manager, Sales Manager, and Service Manager. We apologize for any inconvenience that this issue may cause you or your customers.
Front and Rear Calipers
M0XUVGX013294- 016669
M0XUVGT011480-012186
M0XUVDX011917-013329
M0XUVDT010001-010449
Front Calipers Only:
M0HP4DX050877-051453
M0HP4GX051221-052763
INSPECT BRAKE CALIPER LOCATION
For XUV, check both front and rear calipers for correct caliper installation on both sides of the vehicle.
For HPX, only front calipers need to be inspected on both sides of the vehicle.
The rear calipers are easy to see from the rear of the machine.
For inspecting front calipers, turn wheels hard to the left and view the calipers from under the vehicle passenger platform (right side).
Front Caliper Inspection:
Front Caliper Photo. Look at the bleeder screws (A) and (B). They should be straight with the banjo bolt (C).
Rear Calipers Inspection
Note: HPX vehicles do not require checking rear calipers.
Rear Caliper Photo. Look at the bleeder screws (D) and (E). They should be angled away from the banjo bolt (F).
   / Gator XUV Recall! #6
This is good news. My very early serial number is not on this list. I have never heard this rattling that has been described. However, this is dealing with brakes and not the front differential. Are there two different problems???
   / Gator XUV Recall! #7
They are two different issues...
The brakes are a mandatory recall
The differential is fix as fail
If its not making noise dont worry about it- but if it is take it in since its just an adjustment.
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2014 Peterbilt 337 Forestry Grapple Truck (A50323)
2014 Peterbilt 337...
2015 Ford Explorer SUV (A50324)
2015 Ford Explorer...
2015 Club Car Golf Cart (A50324)
2015 Club Car Golf...
2023 John Deere FC 15R (A50120)
2023 John Deere FC...
