Gator XUV Evaluation (long)
   / Gator XUV Evaluation (long) #1
519NASCAR
Bronze Member
I will give you guys an evaluation of my new XUV with 15 hours on the machine. I give JD an overall thumbs up on this machine. I have basically every option that I can get on it and ran change less than 13K including tax. The overall fit and finish of this machine is very good, which is what you expect when purchasing a JD product. This machine isn't the perfect UTV, which in my opinion none of them are; but, I went with it because for the application that I wanted in a machine it fit me well. The fuel injection engine is great and starts like a dream..............I almost went with the diesel, but didn't want the hassle of very cold weather starting............(just me though). The XUV isn't a tire spinning wonder like the Rangers or possibly others, but for what I wanted it for it will do basically anything. I mainly use it for recreation, light work, and mainly in the deer woods...........hauling stands, feeders, etc. The XUV is very nimble , stable, and will handle most problems thrown at it with ease. It will go through deep holes, mud, inclines, and rock grades with relative ease..........and is a very stable platform while doing it. I like the bucket seats and the way they hold you in the machine when on the trails or in the rock hills. The seatbelt restraint system is an added peace of mind. The diff. lock is very good and I can go through most situations with only the diff. lock engaged. The "true" 4 wheel drive is good also.............although, I do not like the fact that it doesn't kick in till the machine senses rear wheel slip. There are times ahead that I can see where it would be better if all four were there all the time. I will say this though; The 4 wheel kicks in and out flawlessly and without driver awareness unless you are looking at the front tires............and with the "Vamps" you are taking a chance of loosing your head from flying debris. The machine had an awful stance when I took delivery from my dealer.............nose down bad !! I quickly took care of that problem with a 2" lift kit on the front.............machine now looks like it should and greatly increased front diff. ground clearance. The bed space on the gator is excellent and is quite capable of heavy hauling. I have had 20 bags of corn for my feeders in it and it was handled by the machine with ease. The rear did sit down to where it was level with the front and no lower ( I was impressed with this). Power is diminished probably 30% under full load, but still had plenty of low grunt to handle hills and rocks to get to the feeders. I had the dealer install full belly and front and rear a-arm skid plates because of how I intended to use the machine. I would strongly recommend this for the protection of the machine........they are tuff and they work. They will scratch up and sound bad when drug over rocks, but they protect the machine like they are supposed to. The ROPS and top are a charm on my ride............no squeaks, rattles or anything. I have a friend that has a Ranger and his top rattles like crazy...........prolly just his, but it is very annoying. The lights on top of the Gator are cool and super bright, but where they are located simply stink..........I am waiting for the first good limb to tear them off. This design needs to be addressed by JD, or a protective limb guard needs to be there to keep them from being torn off of the machine. My machine's steering is quite easily turned..........even under loads and in full 4x4..............This really suprised me, especially since installation of the 27" Vamps. The downfalls of the Gator in my opinion are few, but I will give some that I think are there. There is virtually now storage in the unit. If I didn't get the cab storage system, I would only have the basically worthless glovebox. It would be nice if JD would make a standard speedo and rpm guage (30 is top speed on mine, but a speedo would be still nice). It would be nice also, if JD would stick on a rear bumper of some sort from the factory....................I can see me backing into a tree and messing up some pretty green paint. I knew of these and probably some others before my purchase, and I still found the XUV the right machine for me. The Gator XUV isn't the prettiest machine, it isn't the fastest machine, and it does have its flaws.............but it is a quality machine that will perform well when used in the manner that it was designed for. Will it get stuck? Heck yea............I have had it stuck and had to winch out. But, I am amazed at how much bad stuff this machine will go through and with the relative ease in which it accomplishes it.................more often than not I will only use the diff lock to go where I need to go...............If it quits going with the diff lock, I will engage 4x4 and back out while I still can without having to winch (I hate getting my feet muddy lol).....................I do not think that there is a perfect UTV out there ,but the new XUV's are good machines that will work and perform for their owners and I am sure that they will for several years when properly maintained and serviced. Are these machines for everyone?.............NO !! But, they are good machines that will either go on the work side and do very well. They will also do a good job on the sport side. This is what JD was aiming for in my opinion and I think that they hit the mark !!!!!!..........................Roger:)
   / Gator XUV Evaluation (long) #2
Thank you for taking the time to write up such a thorough review. Interesting points in there. Well done!
   / Gator XUV Evaluation (long) #3
Nice write up.
I would like to add that there is more storage under the hood.
Also the starters are a bad design if you ride in deep mud.
JD uses an automotive type open starter. I had problems with this on both my hpx's and with my xuv.
The starter will get loaded up with mud/sand and have to be removed and cleaned. (this is my only complaint about the xuv)
I'm not sure why they use a motorcycle engine but not the motorcycle starter. :rolleyes:
   / Gator XUV Evaluation (long) #4
If the front diff stayed locked, you would not be able to steer. JC
   / Gator XUV Evaluation (long) #5
This comment applies to the deluxe cab:
As far as the top front lights are concerned, the trick is to leave the mounting bracket a little loose so the whole light will tilt, swivel etc when hit by a branch. Do NOT tighten it in one position. I have hit dozens of branches with mine and no damage has been done yet. Just reach up, move it back into the proper position and you're all set. They will fold up or back against the curved roof without breaking the lenses or light housiing
   / Gator XUV Evaluation (long) #6
the backing into a tree part is why i made a bumper lol. i got a dent in the tail gate too.i did the bed rails to so i wouln't get dents on the bed sides plus it gives me tie down points. and the lights . i know what you mean there to my first lights was unprotected and they never stayed upright so i made the lightrack to protect them . 4 years of trial and error and field testing the stuff. i just think they need to drop that 29hp kawasaki engine in there 1800.00 for a replacement engine upgrade.
   / Gator XUV Evaluation (long) #7
Another way to mount some lights that doesn't look so bad is to go to your neighborhood ?Tractor Supply and buy some 2" gate hinges (I think it's 2 "). I used one to mount a cable to to fasten my dog to keep him from jumping out all the time. They will clamp to the rops and leave you a bolt hole on the other side to mount a light to. you can them angle the lights more outward instead of upward to keep them more protected. Plus, you can pretty much mount them anywhere on the rops you want. After I bought Deere's light kit, I wish I had done this, but then you would have to make your own wiring harness, but that's not too hard to do. And I imagine you could buy Deere's switch seperate for the dash to make it look nice. Just and idea.
-Funkster-
   / Gator XUV Evaluation (long) #8
In your opinion would the XUV have enough power to easily spread large piles of driveway gravel and large snow drifts?
Thanks.
   / Gator XUV Evaluation (long) #9
It will easily haul any loose material you can fit in the bed up hills that are 20 degrees plus. I hauled dozens of loads one weekend from the lower part of my building lot to the upper part so we could backfill. I guess it was 600-900# of loose clay/dirt per load. It was over 20 cubic yards.
Someone can do the trig for me, but it was roughly a 100' trip straight up the hill and a 20'-24' rise in elevation. My lot is only 2.5 acres, but has a 90' elevation difference from the front corner to the back corner.
Never a whimper and no sign of running out of power. I did have the 4 wheel switch turned on in case it needed it.
   / Gator XUV Evaluation (long) #10
I intend to spread rock on land that may have an inch elevation change total so it sounds like the XUV would have no problem with that. I guess my concern should be if the blade is solid enough with withstand the pushing of gravel, which it should easily do, correct?
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
INSPECTION (A51572)
INSPECTION (A51572)
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
