Gator XUV 850/ Model HPX OPS
   / Gator XUV 850/ Model HPX OPS #1
wrede
Bronze Member
2001 J. Deere 4300
I was changing the oil and noticed the right rear axle shaft rubber boot had broken. Is this an easy repair.? It looks like you have to compress the spring and then remove the wheel hub to get the axle shaft free of the differential, where I assume there is a spline connection. There is grease inside the boot. Is that just a one time (factory) packing, as there are no grease fittings?
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
1996 Ingersoll-Rand VR642C (A47477)
1996...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
Behlen 150 Gallon Premium Stock Tank (A55218)
Behlen 150 Gallon...
