Gator 620i fuel pump problem?
   / Gator 620i fuel pump problem? #1
nehalem2
Western Oregon
JD 1070, JD 4120
I have a 2004 gator 620i with ~150 hrs. A few weeks ago I was dumping a load of dirt (hydraulic dump) by backing into an uneven area. It apparently temporarily twisted the frame. The fuel pump (I found out later) started making a loud humming noise. If I turn on the ignition without starting it makes the noise for a few seconds then stops. I called the JD shop & he didn't seem too concerned, but said I should get a spare fuel pump just in case. I got the shop manual (on CD) but it says nothing about this problem or how to replace the fuel pump. Any ideas on why this happened & should I replace the fuel pump?
-brian
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2007 Toyota Camry Sedan (A50324)
2007 Toyota Camry...
John Deere 468 (A50120)
John Deere 468...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52748)
Koyker Loader...
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
2706 (A51691)
2706 (A51691)
