Oil & Fuel Gasoline in diesel
   / Gasoline in diesel #1
Pird
Gasoline in a diesel.
I picked up the wrong can when filling my diesel YM2210D. I had put in probably less than a quart of gasoline in my tank when I realized I had a gasoline can instead of a diesel can. Do I need to drain the tank and refill with diesel fuel or is it safe to top off with diesel fuel and chalk one up to:
A) Inattention
B) Stupidity
C) Ignorance
D) A senior moment
E) All the above
Please don’t be too cruel with your recommendation.
   / Gasoline in diesel #3
Failing to drain the tank puts your engine at risk of severe damage. Who knows how much gas could be tolerated--I wouldn't take the chance.
   / Gasoline in diesel #4
Don't risk it, it could cost you-big time.
   / Gasoline in diesel #5
Pird,
As of right now it is just a silly mistake. If you want to keep it at that drain the tank and start over. If you don't it will most likely cost you a bunch of money.
I would also put a neon flashing sign on those diesel cans so I couldn't make that mistake again.
Partsman
   / Gasoline in diesel #6
If there is a shut-off on the bottom of the tank, I would close it immediatley! There is no question the tank needs to be drained, even if there is not enough to damage the cylinders you can trash the fuel pump. The internal components of the fuel pump use the diesel fuel as lubricant, gasoline would do the opposite.
Don't beat yourself up, I have to be a front-runner in stupid mistakes. Humility keeps us grounded and eventually wiser. Good luck and I hope you get the problem resolved with no problems.
   / Gasoline in diesel #7
I don't know what size of tank that you have, to be able to say is it is safe of not. I do know that years ago, I worked with a man that put gas in his diesel almost everyday. He had about a 90 gallon tank and would put 5 gallon of gas in at least 2-3 times a week.
Thanks for all the kind replies. I will drain the tank, bowl, and lines and hope I can get it started ok. I will also lock up my gas can and give my wife the key. I am sure I will not inadvertently ask her if she has gas.
   / Gasoline in diesel #9
A service station attendant once inadvertantly put 7 liters gas in my diesel truck. The tank holds 130 liters. We added some fuel treatment and all turned out okay.
Egon
   / Gasoline in diesel #10
Be aware that you will need to bleed the air from the fuel lines before trying to start it.
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2019 KENWORTH T680...
HARDEE RD60M LOT NUMBER 157 (A53084)
HARDEE RD60M LOT...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2015 Honda Odyssey VAN (A51694)
2015 Honda Odyssey...
2022 Bobcat T66 R - Series Skid Steer (A51573)
2022 Bobcat T66 R...
