Gasket Sealants for Diesel
   / Gasket Sealants for Diesel #1
jfharper
Doing an engine rebuild and wanted to check on the type of sealants I should use?
1. Head Gasket (think it is made of copper)
2. Rear Oil Seal Housing to block/bearing cap...this has a rope seal, but the manual says to use a sealant for the gasket between the housing and block/bearing cap.
3. Oil Pan
I just wanted to make sure I did this correct...thanks.
Also, the manual says I should properly lubricate the main bearings when I install them...are they talking about luricating on the both sides of the bearing insert before I place them in the bore areas on the cap and block, or should I install them dry, then put some lucas on them? Any help would be great...thanks.
   / Gasket Sealants for Diesel #2
Generally nothing on the head gasket. RTV silcone for most everything
else, esp oil pans, water pumps, etc, as long as a thinner seal does not
cause clearance problems.
I put the bearing inserts in dry and apply "assembly lube" to the business
side. AL is a special grease for that purpose....better than just oil.
Thank You.
   / Gasket Sealants for Diesel #4
Don't forget to thoroughly clean the gasket surfaces first. I like to use brake-clean.
kj
Yep, my Dad taught me that well. Thanks.
2015 FORD E350 16FT BOX TRUCK (A53426)
2015 FORD E350...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
CAT D5K2 LGP (A50123)
2003 Volvo S60 Sedan (A53117)
2003 Volvo S60...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
