Gas with Ethanol in Small engines.....Do not run engine dry for storage.
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #1
brin
Super Member
Georgia - Mt. Vernon by The Store just 5 miles eas
I just took a lawn mower in for repair to the mower shop that has been here for at least 50 yrs. and I mentioned to the owner that I ran all my small engines dry before storing for any length of time due to the ethanol in the gas...He has been repairing small engines for over 40 yrs. and he grabbed a carburetor he had on the shelf and showed it to me ...it was all pitted and ugly..he said " Do not run them dry....go ahead and leave gasoline in them but with an additive.." He said the carb he was showing me came of a piece of equipment that had been stored dry...with no gas at all...For what it's worth.
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #2
Sounds like H% condensation in the bowl. Residual alc would certainly favor it. I like to run then dry on premix. Varnish finally happens even with additives if you leave stuf in the carb and wait too long. Plus whats in there wont burn. I once had a lawn mower stored on partial tank with no gas shutoff. Wouldnt start on fresh so I drained and rinsed the bowl. Started right up and ran well, but I didnt use it right away. Next day it wouldnt start. The fresh gas had dissolved the remaining bowl varnish leaving a mix that took a torch to light where it drained onto concrete. Once I got more fresh gas into the carb and then used it it essentially fixed itself.
larry
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #3
Do what ever you wish. Draining carbs i think also increases the "gas crystals" that form in the bowl i think. These are like sand and will plug your jets easy. My theory is that there is always a bit of fuel if you just run them dry(not talking about bowl drain empting) there is always a bit of fuel in them, which crystalizes that day or next as it dries. With fuel in it there is less of a drying factor.
Here is a new one. i filled the mower at the farm about 2 months prior, rebuilt the card (key to the story) that trip. Then last weekend returned. Mower cranked up fine then shut off after 1 sec or so. Keppt cranking, tapped the bowl nothing, would start with fuel poured in throat of carb. Knew it was not getting fuel. The gas that was in there was E10 about 1/10 of a gallon from last time. It was so nasty smelling it smelled like it was years old (was in the sun) anyway i pulled the carb. Just as i thought the inlet needle was seized in the void it rides in. I pulled it out with my fingers. It had green algae stuff all around the needle holding it closed in place. I had no compressed air or carb cleaner there, so i rubbed the stuff off and put a tiny screw driver inthe area to try and scrape it off. I then let fresh fuel i added flow though the inlet for 10 secs or so to wash it clean. Reassembled and it fired right up, and wife cut with it for an hour or so fine.
Reason i mentioned i rebuilt it was that the bowl gasket and the drain plug weeped fuel and over a few days would drain the small amount i left in the tank each time. Thus i guess not haveing any effect but the fuel crystals in the bowl. This time fuel stayed in the tank for several months without stabilizer and it went bad. And i have no idea how algae grows in gas? Maybe the moisture the ethonol it soaked up and the gas evaporated leaving just high water content in the carb? This then condensed in the top part around the needle?
I dunno, i will now put stabil or seafoam in the fuel that i leave in the tank. This trip i also got 93 octane 100% gas (before i knew of this problem) to run in it.
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #4
clemsonfor;296201 ...and wife cut with it for an hour or so fine.QUOTE said:
Best part of the story right there!
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #5
Thanks for posting. BTW, did the mower shop recommend any certain additive?
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #6
Always store with a full tank of fuel, no ethenal and use stabil, or sea foam, there is no way to get all fuel out without removing carb and tank. If you do empty all fuel out and not protect the carb with a lube, the aluminun carb will oxidize from air and moisture. Metal fuel tanks will rust also.
How do I know? I maintain about 60 generators, drained, run dry and stored inside and about 35 gas engines on equiptment left outside with fuel in it. The engines stored dry are always having problems, leaking carb gaskets, plugged jets, rusty fuel tanks etc. But you cant fix stuppid, upper management knows better:laughing:
Dave
Dave
Creekbend and all...DrDave is right....I should have posted more but got hurried this AM ...these are the additives suggested and he did say to leave the tank full...prevents condensation and as DrDave mentioned the carb the man showed me was all pitted and gross looking and he said it was from the customer leaving the mower empty...
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #8
Does Stabil leave a coating?
I have a shredder that is run only a couple of days each spring so I'm concerned about long term storage. I use Stabil in the gasoline I buy for it, and also run it dry before storage.
I wonder if using 50:1 2-cycle fuel with Stabil for the last fill before storage - either drained or left in the tank - would leave a protective coating.
Off topic - I had an early (1300cc) Datsun pickup where rebuilding the carb didn't help. The thing barely ran. Its carb casting had become porous from corrosion like described above. I had to get a nasty junkyard carb core and rebuild up from that before the thing ran correctly.
I wonder if using 50:1 2-cycle fuel with Stabil for the last fill before winter storage - either drained or left in the tank - would leave a protective coating.
I am a believer in leaving the tank full of gas with an additive..Stabil or something after seeing that carburetor this AM....I mean, he did not try to sell me anything...I was taking a mower into him...he has been doing this for 40 or more years...he was trying help me prevent damage is the way I took it...apparently you think you are leaving it empty but not really and that crystallize and pits your carb etc. and ruins it.
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #10
Shoot, between me and my father we've been running outboard motors and other seasonal equipment dry for nearly 70 years, before and after ethanol came along. Never saw a carb problem due to that. But I have rebuilt plenty of carbs for friends who left ethanol gas in their equipment over winter. I think I'll stick to running equipment dry at the end of the season.
2022 Ram 2500 Pickup Truck, VIN # 3C6UR5HL9NG130419 (A44391)
2022 Ram 2500...
2018 Terex RL4 Towable Light Tower (A44571)
2018 Terex RL4...
2016 Freightliner M2 106 Braun Ambulance (A42742)
2016 Freightliner...
2004 STERLING  L9500 MIXER (A45046)
2004 STERLING...
MIKASA MTX-70 PACKER (A45333)
MIKASA MTX-70...
2018 FORD F-550 SERVICE TRUCK (A45046)
2018 FORD F-550...
