Gas usage during idling
   / Gas usage during idling #1
RichZ
Veteran Member
White Creek, New York, Washington County, on the V
Kubota 4630 with cab and loader
I did a dumb thing earlier this week. I've been recovering from surgery, and haven't been driving my Ford Explorer. Every week I let it idle for about 10 minutes, to keep the battery charged and everything flowing. The last time I did that, I forgot all about it for about 4 - 5 hours. When I suddenly realized that I had left it idling, I ran out of my house expecting it to have used up it's gas, but the gauge showed it used less than 1/4 of a tank. Is that possible, or is my gas gauge stuck? I really never thought about how much gas a car uses during idling, but I thought it had to be more than that.
Thanks!!
   / Gas usage during idling #2
An idling vehicle does not use much gas as you have shown. Extended idle periods would be a challenge for the cooling system so have someone take you for a test drive in the vehicle while you are recovering from the surgery.
Bob
   / Gas usage during idling #3
My calculations show gas "mileage" at idle to be zero!:laughing:
   / Gas usage during idling #4
Not comparing apples to apples here but my neighbor just did a test of his 2007 Dmax. It used .7gals or about 2/3 gallon in 1 hour of idling. Yes, diesels don't use much but it adds up.
Chris
   / Gas usage during idling #5
Ever need to fix or replace a gas tank? Gauge says it is on E, so idle the rest, right? 4 hours later.......... still running.
   / Gas usage during idling #6
Thanks!!
I have heard from 1/4-1/2 gallon/hr. So not much. I would not go start it every week unless you have an old week battery or a small drain. Biweekly is overkill and once a month is prolly fine!
I know, i have had multiple vehicles for years now. Currently we have 4 between my wife and i, sometimes its months till i start the farm truck. Like now its currently in my uncles yard 1 mile from my farm sitting there with the tandem trailer and has been there for 6 weeks i guess? NOw i cursed myself and when i go to move it next my battery will be dead!!
   / Gas usage during idling #7
seems about right, they say E with 2-3 gallons in them, at .5/hour thats 2 gallons for 4 hours of run time!
   / Gas usage during idling #8
Fords are notorious for their fuel gauges hanging out in the top half for a long time and then the last half quickly going away. So the gauge stays on full much longer than it should.
2/3 gallon per hour for idling a diesel is far too high. Either the measuring method sucked or something is wrong with that engine. I expect half that.
   / Gas usage during idling #9
I was thinking something similar, as i have had loggers tell me that their big cat deisels only use around 1gal/hour when i asked about them just leaving them running while not using them and doing something else.
   / Gas usage during idling #10
He uses a chip/monitor system that is dead accurate. He logs every bit of his fuel since he is self employed. The DIC on the GM trucks is also very accurate.
I set in it with him just the other day waiting on his daughter to get done with Volleyball. We sat for 40 minutes with the AC on and it too .4 gals.
I seriously doubt a big CAT only uses 1 gal per hour. My 28HP tractor uses 2/3 gal per hour average. My F-350 gets 17mpg average so at its average speed of 36 mph for its life that is 2 gals per hour give or take.
Chris
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A50397)
2023 PJ 49FT...
Ryobi Sliding Compound Miter Saw (A48837)
Ryobi Sliding...
5ft 8in Tarter Gate (A48837)
5ft 8in Tarter...
2025 Swict 78in Bucket Skid Steer Attachment (A49346)
2025 Swict 78in...
2012 Peterbilt 367 Day Cab Truck, VIN # 1XPTD49X0CD136567 (A48836)
2012 Peterbilt 367...
Equipment Location (A50490)
Equipment Location...
