gas transfer - will this work?
   / gas transfer - will this work? #1
wedge40
Veteran Member
I have an old fuel pump from a car.. Can I use it to transfer gas from a 5 gal can on the ground up to the tank on the tractor. I takes a 3/8" line, runs on 12 volts.
Wedge
   / gas transfer - will this work? #2
Yes, but be careful of sparks! :eek:
   / gas transfer - will this work? #3
I have used an electric fuel pump to transfer diesel many times , but would be leary of using with gasoline. These pumps are normally submerged in the gasoline in the tank thus eliminating the oxygen factor. If this is an add on or auxilary pump, you still have the wire connections to make and you may be thinking of alligator clips. THIS COULD BE VERY DANGEROUS!!!! One spark could be the end of your endeavor, and your tractor.
BE SAFE! Use a hand pump.
My 2cents worth:D
   / gas transfer - will this work? #4
Give it a try, just don't do anything stupid.
   / gas transfer - will this work? #5
It will be very slow and could be dangerous.
Wedge
This is much quicker and safer.
I can empty a 5 gallon can in 30 seconds with it.
   / gas transfer - will this work? #6
Hey LB, I missed 10,000. Congrats!
Please tell me you don't use that battery charger next to gasoline fumes.
   / gas transfer - will this work? #7
1*Hey LB, I missed 10,000. Congrats!
2*Please tell me you don't use that battery charger next to gasoline fumes.
1*I have no volume of post goal .
If they didn't tally record or display the number of post that would be fine with me.
2*That's not gas.
I forgot to mention this is a fuel pump that you add to boost a car/trucks intake of fuel. I understand about being careful with gas, but I'm going to have the pump at least 2 feet away from the gas can and the hose going into the can will be sealed with the vent hole at the opposite side. The only exposed connection will be the ones I use to connect to the tractor battery.
Wedge
   / gas transfer - will this work? #9
Wedge
I do this all the time at work if we need to take out a fuel tank and it's full:(.. We use a battery jump pack that has an on/off switch. Hook up the ground and B+, insert hose in fuel tank deep enough to remove fuel, put other hose in a drum and turn the battery jump pack on. Then we wait what seems like an eternity.
The pump is a NAPA fuel pump that's made to be mounted in the vehicle. The only time it's dangerous is when someone forgets to turn off the jump pack before hooking up the wires. Sparks and gas fumes are scary mixtures.
   / gas transfer - will this work? #10
I know a liquid transfer pump can do that. This liquid transfer pump pumps 5-6 quarts of liquid per minute. It's battery operated so no wires are needed. Simply insert the pump into the item you want drained and the tube where you'd like the liquid to go and the transfer pump takes care of the rest. Pump measures 24 inches long overall (can be put into liquids about 13 inches deep) and the tube measures 24 inches long.
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55302)
2017 Rogator...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
City of Lakeland (A51691)
City of Lakeland...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2014 FREIGHTLINER...
